As a follow up to my last post, I have now competed my set of three pens in novel (to me) materials: ebony, brass and soapstone. Put them on a Walnut base for as a holiday gift. I hope you all don't mind two posts so close together, but I promise not to post too frequently!
Note: you can see that I had to leave the soapstone quite proud of the hardware as it is very soft and brittle. In fact, I positioned the stone pen so that you can see the mistake/blemish at the bottom, where it joins the tip of the pen. Part of it flaked off slightly when I was pressing in the tip and I had to use CA to stabilize it. Pro tip: if you want to do this, you should either expand your brass sleeves first, or grind down the hardware and glue it in with CA rather than press-fit like normal pens.
Thanks to @Joebobber for selling me the soapstone
