Stuck Epoxy Blank in 3D Printed Mold
jbgifford
Cave Creek, AZ
Had a friend print a 4 wide mold. Tried it with epoxy resin and now i can't get the blanks out. Tried drilling hole in the bottom for compressed air. I did apply mold release. And suggestions on how to demold would be appreciated. Thanks.
Unfortunately 3D printed molds are not easy to demold, especially with epoxy because resin gets between the print layers (those little ridges you can feel) and it holds on. You can try putting it in the freezer to see if it releases but most likely you'll have to cut your blanks out and ruin the mold. Printed molds aren't meant to be used like hdpe or silicone molds. They are either one time use molds or you have to take other steps to prepare it for use. When I print 3D molds for resin I leave the bottom off and line the inside of the mold with clear packing tape. Then I hot glue it to a flat piece of wood or plastic also covers with tape. This makes it easier to demold, and resin will pull away from the tape easier to reuse the mold (after it cools off). If you try to demold it while it's still warm, the printed walls will deform.
Best of luck!
I have used a torch to soften then the print so I can remove hidden magnets on failed experiments. A few seconds of the torch and the mold will soften, of course this is destructive to the mold.
Best of luck!
Ugh. Should have done more homework forst. Thank you. Does Alumilite resin fare better than epoxy?
I use alumilite urethane in 3d molds often but if I want to demold them instead of turning them off, I coat the inside with clear tape. A heavier tape around 3 mil works best.
Here's a video of my process using 3D molds to cast a small bowl blank. The process is the same no matter how big or small the cast.
When I cast pen blanks, I cast a larger block and cut them to blank sizes. I get more character in them compared to pouring one blank at a time.
Well this tells me I've not perused your youtube channel for a while, there are more videos to watch!
I feel your pain and frustration. I once froze a drill bit in an acrylic blank by drilling on the drill press at a high speed. I am a quick learner.
I tried using my 3D printer for molds and it was an epic fail - the layering of 3D printing is not smooth and it basically becomes little teeth stacked on top of each other holding whatever is cast into the mold. Using epoxy just makes it even worse at it tends to stick to everything even silicone molds. At this point I only consider a 3D mold as being single use, and turn them away in process. Not what I hoped when I invested in a good 3D printer, but it does come in handy for a lot of other stuff.
Kevin
In my experience if you want to 3D print any type of reusable mold, definitely go with TPU. Shore hardness of 95A is stiff enough to hold it's shape while still being pliable to bend enough to get the casting out. Plus it stands up to the heat really well. I have a couple single blank molds that I printed in 2022 and they are still holding up great. Just hit it with mold release before casting and it's good to go!
Can you tell me a bit more on your success with TPU? I have a Bambu P2S with the AMS and I've read lots of issues with this printer and TPU - already know not to put it in the AMS, but the horror stories on feed issues have kept me away from trying TPU. However, being able to use it to make some custom reusable molds has a lot of appeal, as its why I bought my printer originally. Appreciate your thoughts.
Kevin
I think you should use Polypropylene (PP). With some care it is magical material. Almost nothing sticks to it, see the failures on the web to glue anything to it. No superglue or epoxy holds. I tested that myself. Now for some practical points:
PP sticks to nothing but itself. You can buy pp-sheets to print on but a good solution is packing tape. I have a creality K1 and use the backside of a buildplate to cover with packing tape. Then, it warps. Warps! Let it cool slowly. And for your use I would suggest to print a couple of layers as bottomcover, wider than the blanks (like a sheet of paper) and print on that the walls for the blanks (like open coffins). If it warps then screw that bottom sheet to a piece of wood, maybe with a little frame or something. Glue doesn't work, remember? :))
When the blanks are hardened out, unscrew and take the blanks out. PP is bendable so it should be relative easy. And your mold should be reusable.
Success
Kevin
I have seen there's some difficulty with Bambu printers for some reason. There's been suggestions to elevate the spool and to disconnect the bowden tube and feed the TPU directly into the extruder. This is supposed to help mitigate bunching on retraction and it's supposed to give it a clear path. I personally haven't ever tried that.
I have Qidi Tech printers and they are set up very similarly to the Bamu (core XY w/ a bowden style toolhead) and don't have any issues directly feeding it through the tube.
I did find a couple Wiki articles on the bambu website that give suggestions on printing TPU with the P series. Honestly, their solution seems kind of silly and over complicated. I would just use a separate spool holder and feed it in like a regular filament and see what happens haha!
I apologize for not being much help.
On my old Ender3 printer always had feed problems with TPU until I printed a new filament guide that moved the exit hole much closer to the pinch rollers. haven't had ANY problems with TPU since.
@ghostshadow - No worries on being much help - the discussion alone is a help, as I trust folks on this forum way more than I do the wild west of Facebook these days.
I did a bunch more research and have found that apparently TPU comes in three different 'squishy' levels. The 95A seems to be the least flexible and does often has some success in the AMS whereas the 90A and 85A are much too soft. I bought a spool of PolyMaker TPU 95A to give it a try. Also read that TPU seems to be most sensitive to humidity, so gonna dry the spool for a few hours prior to printing.
Also going to use your suggestion of printing a separate spool holder and feed it directly into the print head without the normal Bowden tube path. Can't get back to it until next week due to other projects in the way, but will let everyone know how this works out.
@PenPerry - sounds like the polypropylene might be the solution for molds. Gonna tackle the TPU first, as I have some prints that suggest it is best and then try the PP. Thanks for the detailed help!! Seems 3D printing is like pen making - always a new tool, new material, and new method to try......lol.
Kevin
