Ugh. Should have done more homework forst. Thank you. Does Alumilite resin fare better than epoxy?Unfortunately 3D printed molds are not easy to demold, especially with epoxy because resin gets between the print layers (those little ridges you can feel) and it holds on. You can try putting it in the freezer to see if it releases but most likely you'll have to cut your blanks out and ruin the mold. Printed molds aren't meant to be used like hdpe or silicone molds. They are either one time use molds or you have to take other steps to prepare it for use. When I print 3D molds for resin I leave the bottom off and line the inside of the mold with clear packing tape. Then I hot glue it to a flat piece of wood or plastic also covers with tape. This makes it easier to demold, and resin will pull away from the tape easier to reuse the mold (after it cools off). If you try to demold it while it's still warm, the printed walls will deform.
Best of luck!
I use alumilite urethane in 3d molds often but if I want to demold them instead of turning them off, I coat the inside with clear tape. A heavier tape around 3 mil works best.Ugh. Should have done more homework forst. Thank you. Does Alumilite resin fare better than epoxy?
Well this tells me I've not perused your youtube channel for a while, there are more videos to watch!I use alumilite urethane in 3d molds often but if I want to demold them instead of turning them off, I coat the inside with clear tape. A heavier tape around 3 mil works best.
Here's a video of my process using 3D molds to cast a small bowl blank. The process is the same no matter how big or small the cast.
When I cast pen blanks, I cast a larger block and cut them to blank sizes. I get more character in them compared to pouring one blank at a time.
