Bandsaw jig for trimming blank corners?
John Gray
Effingham, Illinois
I am trying to trim the 90 degree corners off of some square acrylic blanks and/or wooden ones. Has anyone made a jig to do this or seen where I could information on such? My idea is to make something adjustable for different size blanks that slides in the miter slot on one of my bandsaws, I have a 14" saw and a smaller Craftsmen the will only cut something that's under 3" high.
HELP!!!!
I do believe that there might be a tutorial in the library. I know that there have been several jigs posted here before. Let me see if I can find one for you.
HELP!!!!
Hi John,
I think that I have put pics of my jig on this forum somewhere, maybe on someone else's post but I can show you what I've done for the pen blanks and it works really well, particularly the improved version on my first one. I cut (remove the square corners) a lot I mean, hundreds at the time sometimes, and it takes no time at all to do a few, just magic...!:wink::biggrin:
You should be able to work out how to do it, if not shoot any questions you have and I will try to help you through...!
Now..., where did I put those pics...???:confused::rolleyes::biggrin:
OK, found my original jig pics...! put these ones first and I will come back with the improved version...!:wink:
Cheers
George
How large are you trying to go? You can't turn the corners off on the lathe?
It depends on what I'm turning. In the case of pen blanks, I just put them on a mandrel and turn. Likewise bottle stoppers. But if the blank is larger, I generally prefer to knock the corners off on a saw.
Actually, the safety instructions that came with my lathe say that if the blank is larger than 3", the corners must be cut off before turning. I tend to take published safety recommendations seriously.
I bought one from Hut years ago when I started turning and it is brand new never used on the shelf. Wish that it was worth shipping I would get rid of it.
