Nice! C2 is hands down my favorite body style for the coupes. For convertibles, I'm partial to the c3 (but only up through '71 or so). Maybe some day...Don't know if I would want to sit next to the engine... when Pontiac had the mid engine Fiero, there was a tendency for the engine to catch fire.
I do wish I still have either my '64 or '65 Stingray back... the '64 was stolen and replaced with the '65 which I sold when I got married the frist time... think the car would have lasted longer than the marriage. My choice would be the '64... it had a 327 engine with a Holley AFB carb that could pump gas through the engine nearly as fast as a gas pump... at idle it just loped, not a smooth idle... shortly after I got it, to check it out on the 405 in L.A. I kicked it up to 125 mph, the front end was rising and I still had pedal left.... last time I ever drove it that fast.
After my divorce in which the wife got the 280Z (a Japanese version of the Corvette) and left me with a Toyota Corolla, I decided I wanted to go back to sports cars... Leased a 1976 Alfa Romeo Alfetta (Needed a back seet 'cause I got custody of the 5 year old )... drove it for 13 years before I couldn't afford the maintenance, plus there wasn't an Alfa dealer in Houston. Was a fantastic car to drive, loved it, but decided Italians must have been built differently... I drove it with the seat titlted back a bit cause the roof was a bit low and by the time I got the seat where I could do the pedals comfortably, my arms were stretched to their max to handle the steering. It did have some peculiarities that made maintenance a little more expensive... it had an X-frame, with a flexible drive shaft (3 pieces joined by hard rubber connectors) I actually broke one of the connectors in Phoenix on my way to Texas when I moved home... spent a day there while the dealer scrounged up a part. a few years later in Houston found I had a problem with the end of the drive shaft that went into the rear axle had been vibrating a little and sharpened it like a pencil... Alfa couldn't tell me which drive shaft I needed (was actually 3 different models used in the Alfetta)... wound up calling my old mechanic in California who knew exactly which I needed and shipped it to me for $600 plus cost of install) then the brakes went bad on the rear end... rear brakes were inboard on the rear end and not on the wheels... I only needed calipers, but the mechanic didn't know how to change just the calipers... wound up with a $700 brake job. When the fuel injectors went out I knew I couldn't keep it.Haha.....European cars cost more cos they can go fast on roads that have bends in them....
