Using Alumilite
Padre
I have been using PR to cast pen blanks, and I'm really tired of the smell. Does anyone know if you can use the luster pigments with alumilite?
Thanks.
Curtis,
I was thinking about the dry luster pigments I have from Douglas and Sturgis, the powder ones.
Except anyting that contains any amount of water.
That's why I said "Almost anything" . I have used Rit dye with PR with some success but I know it won't work with Alumilite because it's water based .
Padre , ALL DRY pigments that work for PR will work with Alumilite including the ones you have .
It will work as long as you keep it dry. If you have a humid shop and leave the package open, it will pick up moisture and can cause problems.
