My Way of Doing Pendants
See more from MrPukaShell
MrPukaShell
Simi Valley, CA, USA.
I have been doing pendants this way using scrap woods that I acquire along the way. Bowl scraps, "freebies" from the vendors and general stuff from around the shop. I start off with a piece of wood 2 X 2 X 1.5 +/-. I mark the center on each side and then use a compass to draw a circle. On one side I use a forstner bit and drill a hole about .5" deep in the center. On the other side I drill a 3/8 hole about an inch deep off center, usually about 1/4-3/8 down from the top of the circle. I mount it on a chuck with pin jaws and first turn it round. Then I do the face and round over the front edge. I then cut the back side and make the pendant the thickness I am looking for. I leave about a 1/2 inch tendon to hold the pendant to the body while sanding. I part it off with a parting tool and sand the back with a hand held drill with a sanding pad. A bath in wipe on poly and buff to a shine. I have put a few pictures together of the process so you could see what I was talking about. I really like the idea of the jigs with off center pin locations and the possibilities that go along with it. But this cost me nothing and like I said it is a great way to use up some scrap pieces. After you turn a few you will get the idea. I will usually mark up about 10 at a time one night and drill all of the holes. Next night turn and give them the bath. 3rd night buff and your done.
Comments welcome....
Yet another way. Great work. Have you thought about parting off the pendants a little closer so you can get more than one from a piece?
That is neat, although does seem like a lot of wasted wood. Seels as thought you could part of 2 or 3 from that piece.
Apology for taking this off topic, but what brand of right angle drill are you using? I have been looking for one and cannot find them here in Japan. My get my daughter to get me one for Christmas.
Back to topic. I like the way you made the pendants! Great photos.
I got the drill off of ebay. In the catalogs and searches I was looking at the drills were always high dollar. I purchased the one I have for $20.00-30.00 dollars. I figured I could buy 3 or 4 at that rate. I have used it quite a bit and no problems as of yet. I would say 50 hours give or take of use.
You are right about parting them off and I have done them that way. I did this one just to show how you and get almost the whole back done except the last kittle bit even with 1.5" thick piece of wood. With 2.0" piece I always get 2-3. For me it is more of a way to get rid of cut offs.
There is an article, TURNING OFF-CENTRE PENDANTS, in the August, 2009 issue of Woodturning (a GMC publication from UK). The author, John Lucas, uses stacks of veneer and removes two jaws of a chuck to shift the turning both up and down and out. Thus, the pendants are thick on one end as well as off-center.
you don't have to buy a right angle drill..you can get just the right angle and chuck it in the drill you have..I've seen for about 20.00 or so...
MRPUKA: thanks for taking the time to show your method & the very good pictures..your method thoughtful & cheap..I like it
