Sanding a Segmented Blank
EzNielsen
Utah
Hello! I've been planning on making this segmented blank for a while. I want to make sure I know exactly how I'm going to do everything before I get started on it.
The question I had was how do you sand segmented blanks while avoiding bleed-out or getting sanding dust stuck to other colored woods?
I'd really appreciate any opinions and/or advice you have, thank you in advance!
I make many segmented pens over the years and have never sanded them. I always use turning tools to get blank round and close to shape I want. After it is all skew work with a sharp skew. After awhile you can go from skew to finish. Now even with finish you do not wipe the first coats on. I suggest a couple light sprays with dewaxed shellac. After the blanks is sealed then finish with whatever you like. Just some of my thoughts.
Thank you for the response! That sounds like a great way to do it. Maybe I'll get more practice with a skew and then use it to help make this blank.
Your use of Shellac is spot on. Prevents colored woods from "bleeding" out onto ajoining woods. Sharp skew is also the go to tool. Good skew work leads to less sanding. Great Job!
Since I'm looking at doing more segmenting, this is interesting. Does anyone use a tack cloth to remove little particles that mix with segments? Curious.
No. Use either air or vac. If you get into using metals then you need to protect the lathe and motor. You can use a good soft paint brush which I do on occassion. I do not like tack cloths because they can leave behind a residue. My go to is mostly a shop vac.
Understood. It's a pain to hook up as the SV is in the basement along with the air compressor.
Get a battery vac. If you are going to do this pen stuff you have to be able to adapt to each situation. One shoe does not fit all. What a vac does is also cleans the area to get ready for finishes. 2 birds with one stone. This is how I look at it. before CA touches any pen blank or other project the lathe area is cleaned.
Wait, am I supposed to clean the lathe area? But the shavings provide a nice cushion to stand on. 🤣
