I have Starbound(medium) and friction polish. I will look for some plastic polish. Can autozone plastic scratch polish be useful or is polish not all the same?. From there I'll apply Gluboost CA (exact formulation of Gluboost depending on resin vs wood pen), then I use Dr Kirks scratch free, followed by the three Dr Kirks polishes
We started out with our sanding station being stocked with 180,400,1500. All sand paper cut to strips. I would like to move to Micro Mesh soon. I appreciate your feedback!I sand up to 600 before applying CA, then I wet sand with 600 grit and then move into wet sanding with micro mesh ranging from 1500-12000. After that I dry the blank and then buff in a plastic polish at higher rpms.
This helps a lot! Thank you. My last 2 pens were a result of what you are talking about.Skipping grits, like going from 150 directly to 400 and then directly to 1500 will most likely not give you the results you want.
It will take several eons (if ever) for 400 grit to remove the scratches created by 150 grit. The same holds for jumping straight to 1500 grit from 400 grit.
FYI, I start with either 600 or 800.
Thanks for all of this.I think the folks that I talk with who turn a lot of pens start sanding at 150/180, 220, 320, 400, 600. Using that 150/180 grit may depend on the blank, sometimes it could be skipped. I know a few people who sand their turnings at the RPM they use for turning, I have gotten in the habit of sanding around 750 ish myself. I'm sure some will say that's too high or too low, it's really what works for you.
Perhaps the most important part is to make sure you sand along the axis of the pen before changing grits so you're not continuing to chase circular sanding marks. It's remarkable the difference that will make. Once it's smooth and perfect, then apply the CA. You probably don't need to sand at 600 again after applying the CA, just go to finishing grits.
I've not used Starbond for a finish, the guys who taught me to make pens all used Gluboost so I just started there and stayed with it because that's what they showed me. I think with any CA the devilish part is finding a way to apply it ripple free. There are probably as many ways there as there are turners on this site.
I have used Flitz polish on pens after micro mesh, I remember looking it up one time and found out it was literally the same polish as one of the big pen polishes just branded differently. I don't remember which one it was. I know automotive polishes can have different grit or "cuts" so you'll want to make sure you're using them in the correct order. The Dr Kirks polish I use is similar to that in the fact that has different grit levels.
I just remembered there are a whole bunch of folks who use the magic juice family of products too. You can check them out.
Post photos of your pens if you'd like also. Plenty of folks on here who will give out pointers, I've certainly learned a lot that way.
Will be watching this in a few with my son. He is 9 and just as addicted to this as I am. Thank you.My first YouTube video many a years ago … (and over 10,000 views).
View it here -
10 Minutes To Better Penmaking - GluBoost
Looks like you are from the Midwest. In April you and your son should come out to The Midwest Penturners Gathering (midwestpenturnersgathering.com). We get about 300 penturners of all ages for two full days of classes and demos. It's always a blast. Feel free to PM me for any questions).Will be watching this in a few with my son. He is 9 and just as addicted to this as I am. Thank you.
I'm orginally from Michigan and have since moved to Florida in 2010. Miss the Chicago and midwest shows, but not into long travels any longer. Anyone know of any pen symposiums or meets that are closer to my home base now in the south?? Would love to attend these since I certainly miss the fine demonstrations and seeing all the new techniques.........thanksLooks like you are from the Midwest. In April you and your son should come out to The Midwest Penturners Gathering (midwestpenturnersgathering.com). We get about 300 penturners of all ages for two full days of classes and demos. It's always a blast. Feel free to PM me for any questions).
This would be great to attend. Is the show at the hotel? I didn't see anything different about venue location?Looks like you are from the Midwest. In April you and your son should come out to The Midwest Penturners Gathering (midwestpenturnersgathering.com). We get about 300 penturners of all ages for two full days of classes and demos. It's always a blast. Feel free to PM me for any questions).
Like I said, we are just getting started. But here is our pens. I tried to take my time with the Hickory/click pen and CA. Everything you stated about grit sequences shows the scratches on my finish. The walnut and african blackwood are friction polish. This thread helps a ton.
exoticblanks.com
Yeah I don't have those type of bushings yet.I think I've learned something from every turning I've done. It all takes a little time to figure out exactly how you like things and what you want done. The nice thing with a CA finish is that it's super easy to redo it. If you don't like it, sand it back down and apply again.
One other thing just occurred to me that I haven't seen anyone mention. Do you have any finishing bushings? The will help prevent your CA from sticking to the steel pen bushings. (ask me how I know) You'll want to lightly sand the end of the blank to make sure the CA doesn't affect your final fit but they really help.
Finishing Bushings - Set of 4
Achieve cleaner and easier CA glue wood finishing for your pens with this set of 4 Non-Stick Bushings. Say goodbye to metal bonding issues during sanding - these bushings are designed to resist CA glue, making your finishing process a breeze!exoticblanks.com
I am getting good turnings before sanding but my son needs time and experience to figure it out. I just didn't set us up with the proper grits for our building.Not sure if I am reading all the comments correctly, but I might suggest looking at your tool handling if you need to start sanding at anything courser than 320, especially with resin blanks.
They are worth every penny, truly. They can be used with other projects too.Yeah I don't have those type of bushings yet.
Those are sharp pens. Work of art really.A good CA finish is going to be about a hundredth inch thick. If you're touching that with anything under 600 grit, you're going to over-thin it, or even sand through it, regularly. Besides you'll never get those scratches out.
My regimen is to turn a hundredth past the finish diameter, measured by caliper. Then apply .012-.015 of CA. I lightly cut off the high spots with square carbide rather than sand. Then apply thin Gluboost, 3 or 4 topcoats, to fill in the low spots. Then wet-sand with 1200 until round, and go straight to buffing.
