Anyone have a friction polish recipe they like better than commercial options?
BHuij
Utah
As I have been primarily a pen turner, I haven't touched friction polish in many years. Basically since I learned how to do a good CA finish. I don't currently own any.
Now that I'm branching out to some other spindle projects that aren't handled as heavily as a pen (chess pieces, spinning tops, etc.), I'm experimenting with some other finishes. CA glue isn't really practical for anything that has fine details or complex shapes. And there's something to be said for the warmer, more tactile "wood" feeling you can get from non-CA type finishes.
My chess set in progress has gone well with hand-applied shellac done off the lathe, then buffed out with some wax after a few days of hardening.
I want to try some friction polishes in the near future. I think I can get Shellawax and Mylands high-build locally. But I'm a DIY enthusiast and already have plenty of oils, solvents, and shellac on hand. So if anyone has a DIY recipe that they particularly like, especially if they like it more than Mylands or Shellawax, I'd love to hear about it. Bonus points if you have photos to share.
I used this at times when using a friction polish - from Capt'n Eddie.
The Recipe (O.B. Shine Juice)
  • 1 Part Shellac (Clear or White, usually 3lb cut)
  • 1 Part Boiled Linseed Oil (BLO)
  • 1 Part Denatured Alcohol (Methylated Spirits)
    YouTube
    YouTube +2
Why a friction polish? If you're looking for a great shine, and it does work, and durability why not try WOP (Wipe On Poly). I've been using it for years and it works great. 3 Coats put on at a high speed, let it sit for 24 hours between coats, and then apply another coat, 3 in total. It needs no buffing (99% of the time) and holds up well (almost 600 knife handles later with no complaints as an example). I've used Aussie Oil and it worked great but I ended up chucking it cause it wasn't consistent, WOP is. Give it a shot. As for CA, you can have it. Never tried it (allergies) but I've received pens from others who have and all I feel is a bumpy mess. Maybe sanding it might help but that's another step I don't want to do. That's my take. Marks does sound interesting though. Good luck in your quest.
You can also try the following:
1/3 oil based polyurethane (ensure it is oil based and not water)
1/3 mineral spirits, again ensure it is the real stuff, not the new "green" crap on the shelves today.
1/3 tung oil.
For a 'friction polish' to be used on smaller items:
1 part Tung Oil (or BLO or walnut oil)
1 part brushing lacquer
1 part lacquer thinner
(Shake before using; wipe on while spinning the item on the lathe while applying pressure to generate heat. Reapply as necessary to build a finish. Final curing takes a few hours. Because this formula uses lacquer rather than shellac, it is harder and is resistant to alcohol.)
For a 'varnish' to be used on larger items (similar to WaterLox):
1 part Tung Oil
1 part alkyd varnish (I use McCloskey's Man-o-War)
1 part turpentine (or mineral spirits)
(wipe on generously, let sit for 30-45 minutes, wipe off, after 4-24 hours, buff with 4/0 steel wool or gray Scotchbrite and repeat; 3-6 applications depending on the degree of gloss desired. Can be waxed/buffed after it cures if higher gloss is desired. For a harder finish, substitute a solvent-based polyurethane instead of the alkyd varnish: curing time between applications will be longer.)
For a 'danish oil' (penetrates into the surface; does not form a 'film finish")
1 part Tung Oil
1 part limonene (or turpentine or mineral spirits - but limonene smells better)
(shake before using; apply generously, and then wipe off excess after 30-45 minutes, repeat if desired)
For a 'cutting board' or treenware finish (similar to Howard's FeedNWax:
Slice beeswax into thin shavings and in limonene, shaking occasionally (turpentine or mineral oil NOT recommended)
After the wax has fully dissolved, add an equal volume of limonene and Tung Oil.
(shake well before using; apply generously, and then wipe off excess after 30-45 minutes and buff. Repeated washing will remove the finish, so periodic reapplication is required)
I generally prefer to use Hope's Pure Tung Oil in making these finishes. It is possible to substitute BLO (yielding a stronger amber color) or walnut oil (for less amber color than Tung Oil.) Be aware that BLO that is made by adding driers to pure linseee oil may not be 'food safe'. There are a few commercially-made BLOs that are produced using the traditional heat method, or it is possible to make your own, that don't carry this risk.
Great answers, thanks all.
I have tried that "equal parts lacquer, BLO, and lacquer thinner" friction polish and found it to be really disappointing. I couldn't really build a high gloss at all. It made a reasonably good satin finish, but one I think I could achieve more easily with just oil.
My understanding of the friction polishes that I've used in the past is that they are shellac-based. I'll have to give O.B. Shine Juice a try.
While I know there's a time and a place for extremely long, multi-day-cures-between-many-coats type finishing processes (my guitar comes to mind), a big part of the appeal of friction polish (and CA finish) is that they can be done right there, cure times measured in seconds or minutes instead of hours/days/weeks. @wolf creek knives it sounds like maybe you have not yet encountered a well-done CA finish. When done correctly, it's glass-smooth. And yes, that involves sanding, but I'll take a little sanding any day compared to spending 6 days on my finish :D
Does anyone know of or have a friction polish that cures to a gloss finish?
Mine is from Captain Eddie Castelin- equal parts BLO, DNA, clear shellac.
You are right, my way does take days to finish. But I'm an old retired guy and if I get stuff done too quickly in the shop it means my "honey-do" list comes out. So I really don't mind the time. Me and CA don't get along. The first time I tried to use it (on a pen) I got one heck of a bloody nose. Almost emergency room bloody so my Dr. told me to knock it off or maybe next time it might be worse, so I stay away from it. WOP works for me so I'll continue to use it, spend more time in the shop making other stuff. :)
Further notes on friction polish -
  • My recollections of Capt Eddie's videos (that I watched) was that he described OB's Shine Juice as equal parts BLO, Shellac, and DNA. However, he could have mentioned lacquer in videos that I didn't watch
  • I believe that there were at least two commercial friction polishes that used lacquer rather than shellac. One is the house-brand friction polish sold by Penn State (which was manufactured and sold in Canada by William Woodright). It was as colorless as water, and I suspected that it didn't actually include an oil component; the MSDS didn't mention any oil, only lacquer and some unpronounceable chemicals that I suspected didn't go well with a ham sandwich. The other was either Hut or Behlens - I never actually used either but I'm pretty sure that one was lacquer while the other was shellac.
Are you spinning your knife handles on the lathe or am I just not caffeinated enough yet this morning and reading this incorrectly?
I'm gonna give OB Shine Juice a try - the most basic recipe of 1:1:1 shellac:BLO:DNA. Apparently Zinnser's pre-mixed shellac is what Eddie uses. I have flakes but no pre-mixed stuff in a can. Anyone know approximately what lb cut the Zinnser's would be?
No, I'm not spinning my knife handles on my lathe. It would be pretty cool but I'd probably not have any fingers left. I was addressing the durability of WOP. Here's an order I did that went to Hawaii. All done in Koa and finished with WOP.
Those all look wonderful. I really like the hand shape on your seam rippers. I keep saying I'm going to make a couple but I don't hardly have anyone in my lift any more who sews! One cousin may get one just so I can try it out. Is there a brand or manufacturer you really like?
As far as WOP, I kind of figured you weren't spinning on the lathe unless you were doing some form of handle for a hidden tang. I have done several skinning and fillet knives over the years and have used Tru Oil. I have a chef's knife I have to order the steel for and set a handle on for a close friend who just retired. I may have to experiment with a poly a little.
Do it. Seam Rippers are easy. I do what I call a dog bone pattern. If you're interested I can tell you all about it. I can turn between 7-8 an hour, so if I can do it I'm sure you can too. I am a production turner for several stores and WOP has always been my finish. As for WOP, I went through a whole bunch of finishes until someone told me about WOP. Best switch I ever made. Easy, cheap and it has never failed me...but that's me. Thanks for your comments and please let me know if you're interested in seam rippers.
@wolf creek knives I am curious if you can recommend any knife "kits" that actually have decent steel and blades? I've only ever made one and it had kinda garbage tier "stainless." My current EDC knife is a folding Kershaw with 8Cr13MoV steel that I'm very happy with. But I would love to replace it with a knife with handles I make myself.
I've always heard that their normal pre-mixed shellac is a 3 lb. cut, but for my O.B.'s Shine Juice I use their wax-free Seal Coat which is a 2 lb. cut. - Dave
Check out Premium Knife Supply out of VA. They're the company I use and have had really good results with their blanks. Good Luck!
