Micro Mesh vs. Tri-M-Ite
qquake
Northern California
Lately I've been using 3M Tri-M-Ite polishing paper, and been getting good results. There are six grades. Just for fun, I decided to try Micro Mesh again, but only using every other pad, for a total of five grades. I think the MM is giving as good results as the 3M, maybe slightly better. With both, I finish them with Meguiar's 105 then 205.
I've tried both and chosen to make the transition from Micromesh to Tri-M-ite for pens.
This is not because I can tell the difference between the results I get using *new* Micromesh and *new* Tri-M-ite paper - it's because I could never bring myself to use those expensive Micromesh pads once and once only.
I cut the Tri-M-ite into strips about 3/4" wide and 2" long and use them once, then straight into the trash. Always have a new cutting face, don't get the ebony dust from the previous pen smudged into the holly of the next one, etcetera, etcetera, etcetera.
I have never heard of Tri-M-ite. I look forward to trying it. I do question only using micromesh once. I have done many, many pens from the same set of pads.
Seven
Same with me. I'll use the same set of pads until the finish starts to suffer.
Not got a lot of experience of MM on wood or composite wood hybrids but I use Mm repeatedly with lots of washing and get good results on plastics. Never tried the 3M stuff yet so can't compare.
I use MM in strips so far , only just got a set of pads to tryout.
Yeah. Me too. I can usually extend the life by cleaning them off with some water and an old toothbrush.
Looks like everyone misunderstood what I wrote, so for clarity: I never threw out a set of Micromesh pads after using them once.
Like everyone else, I used them and washed them "until the finish starts to suffer" - my entire point being that's too late. By switching to Tri-Mite, I never reach the point where the finish suffers.
I'm curious, do you, and maybe others have the idea that MM / MM pads are primarily for one time use only? That is what I was reading in your post.
As to dust transferring, I have never had that problem in 16 years of pen making and using MM. Of course, I clean them, which is what is intended with MM. MM is/was designed for use multiple times.
Greetings. I haven't tried the 3M Tri-M-Ite yet, but I too have used my MM pads many many times. Even with that, being on the frugal side, I bought a bunch of the 2x3-inch sets and cut them down into 1-1/2 by 2 inch pieces instead of paying the premium for the 2x2 pads. The 2x3's were less expensive than the 2x2's to start with, then I got double the product by cutting them down. - Dave
I buy the the 3X4 kit and cut them in half get four times the pads for the price of one. I also clean them periodically with warm soapy water then spread them out on a towel to dry. When using I spray then with water just before using them. The only complaint that I have with the pads is that if you get to aggressive with sanding the abrasive will come off on you blank.
A set if pads i use must be antiques! I keep soaking them in water before us and occasionally brush them with an old and soft toothbrush. They seem as good to me as new, but then, I am a bit of a cheap-skate! P.
I use the 3x4 micro mesh pads, cut into 1x2 pieces. So each gives me 6 pads.
Does anyone know where I can get the Tri-M-ite polishing paper in Canada? I'd like to try it, but a set of sheets from RioGrande, costs as much to ship as the set, and I won't get it until February or March.
Hey Darrin - I'll fix you up with some. PM here or through FB and we can work something out.
How much is Micro Mesh in Canada?
A 9 piece package of the 3x4 pads is $44. But I get six 1x4 sets and I do reuse them. I am actually getting ready to use a new set.
While I plan on cutting up the 3m sheets to 3/4x2 strips, I will be using each piece once and throwing it away.
I don't understand using Micro Mesh pads only once? I've been using the same pads for about 6 years now. I make about 30 or so pens a year... So I'm not high volume. But I have not problem with them. If I use dry, I clap three times on them after use to clear debris. If wet... just rinse them out in clean water.
That's not what I meant. If you read my next post I explain:
In reading your description, I imagine that your technique is similar to mine, I let the sanding paper/pad do the cutting with very little pressure from the hand. If yours is technique is like mine, I can see what you are writing.
But for me, as MM wears, I do apply a bit more pressure, but not much. For instance, I found that 3200 wears and is less effective as a 3200, but it is effective as a 4800 or even 6000, providing I have not applied too much pressure and "burned" the MM. I haven't had finish to suffer as a result of mm wearing. I start using 12000 early as I like a used 12000 because it is more fine. A used 12000, with proper technique is like using a 14000 and is similar to buffing or even polishing (with a drop of water.) For me, an MM grade just moves up one or two notches with use.
BTW, I don't use a drop of water 99% of the time as it can cause problems, so I am very selective on this point.
Hank, about 80% of my concern has been material embedded in the pads. The other 20% is the grit wearing and no longer cutting "like new", which can be somewhat overcome as you say by pressing a little harder or sanding a little longer.
The bottom line for me is that using Tri-Mite, I don't have those concerns any more, and I get equal (if not better) finishes every time.
