Before I forget how...
See more from KenB259
KenB259
Michigan
I thought I ought to actually make a pen. I don't see many bandsaw Celtic knots with multi colored infill. This is a patriotic Celtic knot on a gun metal GT Knurl. Wood is holly with red white and blue vaneer. For inquiring minds , the cuts were partial cuts and followed the 1,3,2,4 cutting sequence.
magpens
Canada
Beautiful work, Ken !!!
Stay in practice !!!
You don't ever want to forget how to make pens like that !!!!
Well done. I do not even want to do a bandsaw knot because i would have to make a jig for that too. Way too much else to do. I am trying so many different things right now. Need to get back to do a few segmented pens to show I still do them. Nice knot and looks exact as always.
Dale Parrott
Goshen, Indiana
First, That is a very nice pen you made. Works for me!
Second, since this is your thread Ken it seems appropriate to ask a question here. Concerning the 3 layer inlay on a bandsaw. I purchase my bandsaw blades from a local shop where they make them to order and they are .025" thick. The kerf these cut is around .040" and my veneers are about .020" thick. Using my existing blades and veneers there just isn't room to get 3 layers and maintain the blank dimensions. Looking for a solution to get 3 layers not just from Ken but also the members here. Thanks in advance.
The obvious answer which I am sure you thought of is get a wider blade. A resaw blade will be wider especially the carbide ones. They are usually 1/2" to 3/4" wide They will be thicker. I am sure Ken will give you his dimensions on the blade he uses and the material used.
Dale Parrott
Goshen, Indiana
Thanks JT. I'm thinking the 1/2" and 3/4" won't cut the tight curves. Actually not sure the 3/8 will either. I used a 1/4 on my last posted project.
Dieseldoc
Livermore, Ca 94550
Dale:
I use knife building material from alphaknifesupply.com that is 0.015 thick with any band saw work that needs very thin color infills segmenting. Also make my own wood veneer with the Byrnes drum sander.
Charlie
KenB259
Michigan
Dale:
Charlie
I will check their thin stuff out. My bandsaw kerf is .048, so I need infill at .015, to get three in there.
KenB259
Michigan
I sand it down to whatever size I need it to be, I can actually sand vaneer to size.
KenB259
Michigan
I buy Timber Wolf Blades, current one on is 3/16. I imagine, even blades of the same manufacturer, would vary somewhat, everything has a tolerance. That's why I never cut a bunch of infill at once. I cut and sand it as needed. Found out long ago, that it will shrink and grow on you, depending on the humidity.
Dale Parrott
Goshen, Indiana
Dale:
Charlie
Charlie what is that material made of and what kind of glue do you use with it?
Richard92
Boston Lincolnshire
That is really nice Ken appreciate the information on how you achieved it . I find doing the infills can be a pain. Do you mainly use vaneers for your infills as they are expensive in the UK?
Dale Parrott
Goshen, Indiana
Thank you. I had assumed the veneer wasn't strong enough to be thickness sanded. I just gave it a try and went from .022 down to .016. Not a problem just go slowly. This is the thickness sander I bought and love it. Used my own motor and put a dust port on the top.
https://www.vanda-layindustries.com/html/the_hog_sander.html
KenB259
Michigan
Vandaly industries. Interesting. Wasn't there a Seinfeld episode with George pretending to work for Vandelay Industries. I thought he made that up. He then comes running out of the bathroom with his pants down by his ankles when Jerry picks up the phone but George did not tell him to mention the company because he was trying to scam unemployment or something. I laughed pretty darn hard.
KenB259
Michigan
I was remembering that same Seinfeld episode myself.
Dale Parrott
Goshen, Indiana
It was a classic episode. I loved that show.
