manik
Maybe use your stabilizing resin tanks and get a chunk of dry ice from the store. It will sublimate and push all the oxygen out.
If you dont want to use the ice than maybe just squirt the CO2 gas into the tank?
Could mount the leds on the side and just put the blank in vertical on a stick and rotate.
Could also use a small fish tank from Goodwill if you don't have a resin tank.
		 ). That is how I first started using it. Gary, the inventor, and I discussed  formula for pen finishing. He made me some that uses a different curing process - but not for sale yet. However, I want to use, and do use) the formulas that are available now.  I would encourage you to call him. We wrote each other a dozen or so times and I spoke to for hours over several conversations.  Several members here state that they don't have to go through what I do. I can't do it their way and achieve a crystal-clear finish.
