Any ideas on sharpening bead tools?
bsshog40
Omaha, Tx
I dont have a problem with sharpening the edges of these but they are basically useless if I cant sharpen the inside of the bead area. Any suggestions?
Thanks, Bobby
bsshog40
Omaha, Tx
Do they sell them as a mixed size set or do I just get one that is the smallest bead size and use it for all of them?
eharri446
Marietta, GA
Lay the flat of the tool with the bevel pointing thin edge down on a piece of 320 wet or dry sand paper on a piece of glass if you have one or any flat surface and rub the flat of the tool on the sandpaper. You can also use a sharpening stone of you have one or even one of the diamond credit card hones. That will put the angle back on your tool.
As mentioned you do not sharpen the coves, you sharpen the flat edge and just a touch up with a diamond card is all you need. Same thing with scrapers. Flat side
JimB
West Henrietta, NY, USA.
You can get them in different sizes to make different size beads.
You can also learn to roll beads with a detail gouge or skew so you can make any size bead you want.
bsshog40
Omaha, Tx
That is a good video. I have been practicing doing beads with my gouge and skews. I just bought the bead tools thinking they would be a nice easy bead. I think I'll grind them and just try to sand the inside. Thanks y'all!
lorbay
BC. Canada
Well without one of his beading tools doing these handles would be a real chore.
3 beads on each one, and 200 a month.
Lin
duncsuss
Wilmington, MA
I'm not sure if you understood exactly what people were telling you.
They were saying, in different words, "DO NOT try to sharpen the inside".
Take the bead tool, lay it flat on a sharpening stone, and slide it around.
bsshog40
Omaha, Tx
Ok, so these are what my bead tools look like. I can sharpen the outsides but it feels like the inside of the coves are not sharp. They will start to cut the bead but burn my wood more than it does cut when it gets to the cove. So sharpen these flat?
Yes If you start sharpening inside the cove you run the risk of changing the profile shape of the cove The inside doesnt do the cutting it is the flat on the back side that cuts. This idea is applied to any scrapers and a beading tool is basically a scraper. Happy Turning. :)
Charlie_W
Sterling, VA USA
Here is a pic....as John said, you sharpen the top or back of the beading tool to create the sharp edge where it intersects with the curvature. Note the tool is upside down on the diamond hone to take material off the top.
Hope this helps.
