AR 15 .223 cartridge pen kit
Atwerz
Odessa, Texas.
Does any pen kit seller make a kit for an AR 15 .223 bullet? Many, many vets and turners would love to buy the kit. The pens would be a great seller.
The shell casing is too short to look good, this is the way I make mine. This was made off a Slimline kit as an experiment to test the idea. The top and bottom wood blank was cut to length and tubes glued in. The shell casing was resized using reloading gear the bullet was inserted, then cut in half. The bullet was drilled for use as the nib. The blanks were turned to size and the ends cut smaller to insert and epoxy inside of the brass.
Are you saying the case was fully resized? That is a nice pen. I have access to a gun range with tons of empties on the ground. Rinse them off and put them in the polisher.
Basically I went through the steps to reload the brass without powder or primer. I then cut the brass in half, and I added epoxy to hold keep the bullet in place. Then I drilled out the bullet so it functioned as the nib. All was done using a collet chuck. I tried drilling the the bullet both ways, before insertion and after it was epoxied in place. Both methods are not perfect, there will be rejects from them getting marred or just being stubborn.
The primer end also has to be drilled so the tube will extend up so the finial can be pressed in with the clip. I made custom sized hardwood collets that fit in a 3/4" collet to hold the primer end. Actually I believe I drilled the primer end out before cutting in half, some will get screwed up.
An AR 10 casing (7.62/.308) is nearly perfect in size for a slimline. I copied this style from a pen I saw and love it.
I just wanted to make a safety call out. Make sure you are wearing a mask if you drill out a fmj bullet. I like using Barnes Vor TX copper bullets when I add a bullet to a pen. They are completely made of copper and the polymer tip is just about the right size to give you a really clean and finished tip when it is removed to drill through the center. Just my 2 cents. :)
I make my .223 and 22-250 rifle cartridge twist action's using 2 casings and an actual bullet nib.
Using casings for the top section keeps it in proportion to the barrel section.
Les
ar15 casing
the ar15 casing is made out of steel hard to drill and when polished it looses it protective coating. I have made a few but getting them drilled is hard being made of steel i have trouble holding them steady enough to drill without messing up their coating. if someone knows how please let me know
correction ar15
i was thinking about the ak47 when i said the casing was made of steel. my nephew who was a green beret sniper said he shot a 308 this may help you with your vet customers . sorry about the mistake
Any cha
An
Any chance of a walk thru of your technique. Regards Mike
Here are a couple images of .223 pens I have done. The casings are resized, bullets drilled and pressed in and then a 7mm tube installed in the casing to accept the 7mm transmission. You have to get a little creative with the tube length in the upper half to compensate for the length of tube that has to stick out of the casing to ensure proper ink protrusion.
