Atwerz
Does any pen kit seller make a kit for an AR 15 .223 bullet? Many, many vets and turners would love to buy the kit. The pens would be a great seller.
AnI make my .223 and 22-250 rifle cartridge twist action's using 2 casings and an actual bullet nib.
Using casings for the top section keeps it in proportion to the barrel secti
Any chance of a walk thru of your technique. Regards MikeThe shell casing is too short to look good, this is the way I make mine. This was made off a Slimline kit as an experiment to test the idea. The top and bottom wood blank was cut to length and tubes glued in. The shell casing was resized using reloading gear the bullet was inserted, then cut in half. The bullet was drilled for use as the nib. The blanks were turned to size and the ends cut smaller to insert and epoxy inside of the brass.
