Bottle opener dimensions?
thewishman
Reynoldsburg, Ohio, USA.
Looking at adding bottle openers to my offerings. Can anyone tell me what the diameter of the base is? Not the hole that needs to be drilled, the part that caps the hole.
Thanks in advance for the info!:smile:
Berea?
PSI?
I have one out in my shop - I'll measure it later this afternoon when I get a chance to go out there if you don't get an answer before then. I believe it's a PSI kit - I got it from Woodturningz.
Apparently it is a nominal 3/4"'dia. I only have one on hand right now, but I measured it to be 0.77" on the inch scale & 19.55 on the mm scale. This is the PSI PKBOTTCH kit.
I buy my openers from Rockler. A little more expensive than some of the others but I like the look and feel of them. They are 1" in diameter at the opener end...
attachment.php
http://www.penturners.org/forum/attachment.php?attachmentid=147536&stc=1&d=1460815883
