Start of my first practice bowl
See more from Band Saw Box
These chisels with the "swept back wings" and "irish grind" ... would they also be termed an Ellsworth Grind bowl gouge?
I get my chisels from Harbor Freight. 18 bucks .... extremely poor workmanship, but there's nothing wrong with the steel. They come out of the box pretty much blunt enough to bruise someone if it landed on their foot, but not cut them. (yeah, that bad)
The lighter side of the equation is ... at least you'll learn how to sharpen your tools! =D
"swept back wings" "Irish grind" and "Ellsworth grind" are all basically the same thing.
Overall the biggest difference is the angle.
attachment.php
This is the ones I use.
attachment.php
I use this irish grind, it's 1/2" for more detailed delicate work, sharper angle and highly aggressive.
attachment.php
I found the source of the chatter and hard cutting....please don't let this get out...I somehow switch my lathe in to reverse
edstreet I like the look if that bowl and the tools you had the link for I think I'll give that a try on another bowl. Oh thanks for the nice comment.
I have a question as I get set to turn the inside of the bowl. What would be a good caliper to use to keep the sides of the bowl uniform.
Dan, here is a basic calipers that works well for bowls.
I do have one of those. It does come in handy in a few cases however it is very small and not suitable for any decent size bowl, especially for the bottom. For this reason I posted and suggest the big red one be used. It offers more room than needed so you will never find a case where it will not work on the lathe he is using.
