If your dye bottles are brand new, you need to pierce the tips in order to get the dye to flow.  I use a tiny drill bit in a cordless drill...probably overkill, but a simple straight pin seemed too skinny.
For first timers, the Clear is a better choice as you get longer open time and the color is more predictable.  The white lightens the color quite a bit when it goes off so it takes more experimenting to get the final shade of color you wanted.
Also for starting out, adding the dye into just Part A is reasonable, but before you do that, mix a batch or two without yet adding dye to Part A so you get a first hand idea of how long you'll need to mix to get A & B completely mixed.
Lately, I add the drops of dye I want to EMPTY cups (one cup for each color I want in the final pour).  Mix all of the A & B you'll need for call colors with NO dye and then pour some of that into each cup of waiting dye.
That lets you get the exact amount of dye ready in advance.  Be certain to scrape the sides of each cup thoroughly as the dye will tend to stick a bit (but comes off if you try).
You could put a tiny bit of Part A in each cup along with the dye and stir well to get the dye in suspension before adding the mixed A&B.  Then mix all the rest of the A&B together, and add to the dye cups...but, odds are, you'll be slightly off with the ratio of A to B so you'd want to experiment first to see if that will affect your final results.
