robutacion
Hey George,
I hope you haven't posted those blanks back to me yet. If you still have them please either keep them or chuck them in the bin, as they are pretty well useless and I do have a heap more here.
I have been trying some different ways of doing a CA finish while you have been conducting these experiments, and everything I have tried has failed, even to the point of the wood peeling off the tube in my hand. That was not a failure from insufficient glue when fitting the tube, because when the blank was almost to its finished size I applied heaps of thin CA which appeared to be soaking in. It was not until I had applied 1 thin and 4 med coats and sanded and was about to apply the next coat that I realised that the tube and wood had parted company.
There is obviously some kind of resin/inhibitor in the wood which prevents the intake of liquids.
So, chuck 'em out. Don't waste any more money or time.
Thank you so much for all your effort. Like you said, win some loose some.
Cheers,
Bob.
Well Bob, too late mate, I posted them (7) + a gift blank, this morning...!
I have left the turning of the sample a bit too late this afternoon and when I finished it, was almost dark so, I didn't have enough natural light to take a few close ups so, I will do it tomorrow...!
I was a bit surprised when I read your post, the sample that I made looks pretty good, in my eyes and surprisingly, the first 2 thin CA coats I apply to it, not with the applicator but with the lathe off and covering the area with the CA and then smooth it up with the finger while rotating the chuck manually, the wood soaked it quite fast and furious, a little sanding and 6 medium coats followed by 2 thin coats, sand and polish...!
I got the impression that, after I finished the first 2 coats and smooth it up with 600 wet sanding manually, the surface felt extremely hard and smooth, I felt that at that point, I should have give it one more thin coat, and polish, sometimes less is better but, I continued on as normal nevertheless I felt that I passed the ideal finish barrier, anything over, could change its adhesion and performance, with peeling or all the other things your experienced so, its done so, I can't go back, well I could but is not necessary...!
Lets see what this one does, the wood is beautiful and if if holds, you know you have another 7 workable blanks to use at some time...!
And if all goes to $#!t, at least we tried...!:biggrin:
Oh..., I have no doubt that the wood has some chemical component that bleeds out quite easily, that has been my claim from this testing's, sometimes I can reverse its negative results sometimes but rarely, I don't...!
Cheers
George
