Anyone tried putting glass in blanks?
Yes, glass rods, imbedded in PR and set up so they would NOT be hit with any turning tools
Im thinking of using beach glass. Would it break apart when turning?
Would you mount a coca-cola bottle on the lathe and start turning?
Have to be sanded and not cut with a tool?
If it's sanded, will it get hot? If it gets hot, will it fracture?
Carbide tip tool do the job?
I'll leave this one alone--you can try if you like.
Thanks for your input.
As one who would normally take a risk and try anything, I would probably think twice on this one. The probability of injury is too high and I don't care what type of tool you are using, if you hit a piece of glass with it turning you are going to have a very quick glass shard storm.Anyone tried putting glass in blanks? Im thinking of using beach glass. Would it break apart when turning? Have to be sanded and not cut with a tool? Carbide tip tool do the job? Thanks for your input.
That sounds amazing! I say try it and see if it works. You miss 100% of the shots you don't take.
If you really want to work with glass exposed in a pen blank, you might do some research on techniques for working with vitreous enamels (aka glass fused to metal). You might be able to get reasonable (but not gallery quality) results without spending a fortune on tools if you have glass pieces that are already close to the right size and shape. I suspect most of the work (grinding with diamond files) would be done with the lathe turned off and involve mega upper body workouts.
Ed
SHHHHHHH!!!!!!!
I'm working on it.
Enamels actually come powdered, so size and shape isn't a problem really.
Problem is actually the metal (can only use Fine silver and PURE copper, Our brass tubes don't even come close to working) and getting an even coat (tends to want to sag on a round item)
it needs to be a zinc based alloy in order for the enamel to stick. whatever your metal you can always zincate it. coppers pretty much universal however. not much won't stick to pure copper.
let us know how you get onI've considered giving this a god for filling in etching as suggested by Ed in the past.
You don't have to be limited by the brass tubes in a kit Mike.
Ed
