Roman Harvest Rollerballs
See more from jjjaworski
jjjaworski
Las Cruces, NM
A couple of Roman Harvest Rollerballs in Rhodium and TiGold accents.
Those are looking good. Can I ask with the thin walls of a RH, what was your process for painting and glue up? I just did one toady and it was a disater with glue showing where it didn't stick. I painted the tubes then 5min epoxied them.
James, like them both, good match of component and blank.
Jorge, paint the nside of the blank instead of the tubes, then the glue is between the tube and the paint.
Very cool! Fit-n-finish are spot-on.
Psst, grab that chunk of wood them great pens are laying on in the photo shoot, and turn it....I bet it looks awesome inside!
Scott
At first I used to do the same thing, paint the tubes until I used a very translucent blank and saw the air pockects in the epoxy.
As Roy says, paint the inside of the pen blanks prior to glueing in the brass tubes. On these rollerballs I used some Liquitex acrylic paints I have kicking around. Antique Bronze one and Antique Silver on the other. Since the blanks were pretty translucent I applied a second coat in case of streaking.
I took a small dab of the paint on a toothpick and colored the epoxy as well.
The two Roman harvest Fountain Pens I made with these also have thin walls as I like the look of straighter barrels.
The blanks in the picture are from BearToothWoods, top to bottom:
Berea AA-44
BearTooth Acrylic Lemon Peel
Amalgam-Mutt Louisianna Lava
BearTooth Acrylic Rage Red
  • Roman Harvest blanks:shade.jpg
Berea AA-44
