I also use the punch set from Harbor Freight, but added my own jig to more easily remove the transmission:
I drilled a hole only a fraction larger (in diameter) than the transmission lengthwise through a 2"x2"x5" piece of pine. I used pine, so the "softer" wood would have less of a tendency to mar or damage the end of the turned blank. Having previously removed the tip of the pen (also with one of the punches from H.F.; see Fangar's excellent explanation above), I insert the proper sized punch into the pen blank, up against the tip-end of the transmission, place the piece of drilled pine over the transmission that extends out the other end of the pen blank, put the whole deal into a Bessey clamp (use whatever clamp you have that fits), and slowly press it all together. The transmission slides effortlessly out into the pine and voila, you can start all over and put it together right. [
I intend on drilling pieces of 2x2x5 pine for each size pen/transmission that I find I need to disassemble. Way cheaper than the disassembly kit. [
Nancy
