We often hear the following rule for calculating a tap drill size to match an existing threaded device:
"thread diameter minus thread pitch"
For example, for a M10 x 1mm threaded device, the thread pitch is 1 mm, and so the required tap drill size would be 10mm - 1mm = 9mm.
I am wondering if this rule is reliable for small diameters, in particular at 6 mm ( M6 ) and below (the size range for some nib feeds).
I have been working with tapping a hole for a stated M4.2 x 0.35mm threaded device and I have the tap of this stated size.
Having some difficulty with the threaded device not fitting the hole threaded using the above rule.
Based on the rule, I calculate the tap drill as follows: Tap drill size = 4.2 - 0.35 = 3.85 mm, or 0.152" which matches a #24 drill bit.
The tapping process goes just fine, but the resulting tapped hole is too tight for the intended threaded device to fit.
Because the threaded device is brass, I do not want to risk forcing the insertion for fear the threaded device would be destroyed.
There is the possibility that the specs for the threaded device are incorrect.
There is also the possibility that the tap being used is not the correct one, although the marking on the tap is correct numerically.
(I do not have the ability to check the threads on the tap, being as fine as they are.)
There is also the possibility, I suppose, that the threads are burred so that the device cannot smoothly thread in. . Have tried several times without success.
One train of thought would be a "trial and error" method, trying drills of successively larger sizes.
I have done this and I do not like where this is leading, which is to a tap drill size that is getting very close to the OD of the tap that I am using.
I believe that the "rule" quoted at the beginning of this post is a kind of "rule of thumb".
So I am questioning its validity for small diameter threads.
I would appreciate comments/suggestions from anyone "in the know". . Thank you.
