@RGABEL
Rob, another possible factor ..... the click mechanism itself. . I was alerted to this last night when "playing with" an older pen with SKM-88.
It is not a Sierra Super Button Click, for which the mechanism is not actually removable. . It is a PSI Duraclick EDC which does allow removal.
The SKM-88 mechanism has attracted a kind of reverence, but it does have a weakness and might be the culprit in some cases.
The mechanism is not sealed .... tiny bits of debris can get into it, most likely at the lower end where the internal grooves can be seen in the button-depressed position. . There is a tiny, rolling ball riding up and down in the groove pattern. . . Debris could inhibit the smooth motion of that ball and result in failure of the mechanism to extend/retract fully.
The pen I was playing with definitely has failures in extending/retracting fully.
I replaced the mechanism with a new one and the operation became reliable again ..... replacing the first mech. caused return of problem.
The next question is how to further examine and correct ... I do not want to disassemble the mechanism ... there are pics on IAP of internals of the SKM-88 and disassembly is not on the cards for me.
I feel inclined to bathe the mechanism in a light alcohol solvent, while at the same time activating the button in hopes of dislodging the suspected debris. . I don't think the alcohol will do any harm as the mech is all metal.
I'll try this and report back any improvement in operation. . . Meanwhile, any further insight would be appreciated and welcomed.
@RGABEL - Edit / Update / PROGRESS
So .... I got an empty pill bottle, half-filled with Methyl Alcohol, put in the SKM-88, capped the bottle.
Then I shook for 10 seconds or so; waited 5 minutes; repeated ..... for 30 minutes.
Removed SKM-88 mechanism from bottle, blew off the mechanism, allowed to dry (?) for 10 minutes, blew off again with compr. air.
Re-installed SKM-88 in the original pen.
Clicked the push button 100 times in fairly quick succession ...... 2 failures to fully retract/extend. ( 2% failure compared to 20% previously )
Waited 5 minutes; clicked the push button 150 times; NO FAILURES ( 0% )
I would say this has successfully cured the problem ..... will do another 100+ click test later in the day. . CAUTIOUSLY CLAIMING SUCCESS !
