bitshird
I just had a friend drop off a bunch of Bradford Pear that was curt yesterday, I don't have any anchorseal or any thing like it, the wood is still pretty wet , one piece is from right at the ground and will make a killer bowl if I can keep it from checking, I de barked it with a wood chisel, the bark came off easy, but will poly work as a quick sealant, I have a can of minwax waterbased poly, does that sound like a good solution.also have a lot of 2 and 3 ft long sections around 3 to 4 inch diameter should I try and cut them short and seal them or leave them at that length.
