Product Review Evapo-Rust
NewLondon88
Local Chapter Leader
Claremont NH
Product: Evapo-Rust
Harris International Labs
Like anyone else with shop tools, I've had to fight rust problems now
and then. I've tried the naval jelly, steel wool, wire brushes and the
sprays that turn the rust into a 'primable surface'. When I saw the
ad for Evapo-Rust it looked interesting, but I couldn't find it locally.
My first trip to a Harbor Freight solved that problem.
The claims are simple enough. Non toxic, biodegradable, non corrosive,
non-flammable, no VOC's. It sounded sort of like decaf..
what's the point?
For $20 a gallon, it might be worth trying out.
The manufacturer says it will remove heavy rust completely.
I looked through the shop to find an appropriate test.
The directions are simple enough, too. Dip the rusty thing in the
Evapo-Rust and let it soak. 10 minutes for light rust, more for
heavy stuff. Then rinse it off. Check for rust removal and if needed,
soak it again.
I disassembled the old Bailey plane and got the rustiest parts into
a bath of Evapo-Rust and let them soak for a half hour.
The claims of 'no bad odors' might have been made by someone
who is always saying things like "Pull my finger" . I found the odor
to be a bit objectionable, so I just used a tupperware container
and put the cover on . No more odors. With larger objects this
might be more difficult.
After the half hour I checked the progress. The rust wasn't gone,
but it was obviously better.
I used a green Scotchbrite pad and removed the heaviest rust,
but I didn't put any effort into it. (I didn't want to skew the results)
I merely wiped away the loosened rust so that the liquid could get
inside faster (and I could see what was going on in there!)
I ended up soaking everything overnight, rubbing with the Scotchbrite
(ok, scrubbing) and soaking again overnight. after all, these were
pretty badly rusted parts.
They cleaned up a bit without effort. They cleaned up much better
with a bit of scrubbing. Best results don't come without effort, but
it is much easier than other products I've tried. It won't give you
back a brand new finish, but it is much better than throwing away
some perfectly good tools or slapping a coat of paint on them.
After rinsing in water, you can dip them back into solution to give
them two weeks worth or rust protection. After that, you'll need
to treat the metal in some way to prevent the rust from coming
back.
Evapo-Rust
Harris International Labs, Inc.
2078 Ford Ave.
Springdale, AR 72764
TEL: (479) 756-9877
FAX: (479) 927-3202
FREE: (888) 329-9877
http://www.evapo-rust.com
VisExp
Palm Coast, FL, USA.
That evap-o-rust is some good stuff. The rehab job on the plane looks great Charlie. Now you just need to turn and carve some new handles to totally customize it.
NewLondon88
Claremont NH
With slight rust, the metal looks new. Shiny enough that I wondered if it
was the Evapo-Rust or the scrub pad doing it. Lightly rusted parts come
out looking great.
The heavy rust (when the metal is gone) can be made to look much better,
but not brought back to 'new'. It leaves a black carbon coating that rinses
off easily. You can see on the plane that there are some areas that are
pitted.. no way to save that, the metal just isn't there anymore.
The next step on the plane is to see if I can bring the wood back.
But they don't make any Evapo-Dent that I know of.. I do have some
nice caribbean rosewood that isn't doing anything special right now..
Hey Doug .. this stuff is easy on the skin. :tongue:
maxwell_smart007
Lead Moderator
Staff member
middle of nowhere in the great, white North
I tried some out based on your review, and it worked really well! I didn't smell bad at all; in fact, it had no smell until after it disolved some rust, then it smelled like rust!
Mine came in a clear bottle, but has the same logo and name, so perhaps the Canadian stuff is less potent? It worked very well on some stuff, but didn't do much on others. I found that once it turned black (overnight), it left a film that was difficult to remove. Rinsing didnt' seem to remove that black coating on some high-carbon tools though....
Overall, i was impressed; not like-new results for me, but better than anything else I've tried!
Andrew
NewLondon88
Claremont NH
Yes, it will leave a black carbon coating if left in solution. It will come off with a
bit of elbow grease and a scrub pad, steel wool etc. Not terribly hard, either.
But I think that's part of the chelation process, turning the iron oxide back into carbon?
I dunno.. I'm talking over my own head now.
