Before we start, the rubber on many tools such as planners is subject to cold hardness and the lack gripping ability so that is out there. You could take a heat gun and blow hot air on tool before start planning and see if that starts pulling. If so you found a problem. but the cleaning thing and blade change could also be necessary. As with all planners there are certain things that need to be looked at before diving too far into whys. In order the blade may need to sharpened or replaced, second the rollers need cleaning, and third the bed needs cleaning a waxed. These all help maintain the roller feeding. If you are planning lots of resinous woods the rollers as well as the bed and knives will build dirt and grime. So start there. Clean the bed and put a good coat of wax on. I love minwax butchers wax for table tops and things like this. Rollers should be cleaned with Naptha, mineral spirits or acetone. Some rollers will get spongy and soft if they react with the product you are using. Now you are just wiping on and right off so should be fine. You can test on end of roller before committing. If it gets soft then do not use. Blades are self explanatory Dull blades are always problems. Rollers need more cleaning than what people realize.
Now if all these things are done and still having problems. other things to consider. First is dust collection. You need good dust collection because if dust keeps building on board it will hinder grip and if large piece are falling on board it prevents the entire roller to grip the board and thus stutters. All the above things will cause hesitation or random starts and stops of feeding.
But what is getting to me is your statement in that you said the rollers stopped feeding. So I am assuming they just do not grab at all or make any attempt to grab board. Then that is a whole other set of problems but easily checked. The chain for the rollers could be slipping for various reasons. The tension spring is loose or broken, the key on one of the sprockets has snapped (maybe because too big of a bite) or knots in wood. or sprockets have become loose. You need to take the side cover off and take a close look. That is a very good planner.
