I started turning pens earlier this and so still consider myself a beginner. I'm having a finishing problem and am wondering if anyone can offer some advice.
I moved from wood to acrylics pretty quickly and have had some great results, even selling some pens to a local store. For finish on the acrylics, I had been doing great with a regimen of sandpaper (220,300, 400, 600), then micro mesh (to 12,000) then buffing (tripoli and white diamond) and then plastic polish.
I know some of this is overkill and/or going backwards and forwards, based on other posts I've read previously. But it worked.
On my last couple of pens, however, I'm still ending up with some very, very minor scratches that I can't seem to remove no matter how many times I go back to the buffing process. When I compare my latest pens to the very first acrylics I turned, the earlier ones gleam, even though they were made months ago.
On those first acrylic pens, I wasn't using the tripoli or WD. I would expect pens that I buffed to shine even more and, at least initially, the ones I buffed looked great.
Here's what I'm wondering:
1. Is it possible the Micro Mesh discs have worn out already?
2. The earlier acrylics (the ones that still gleam) were made with blanks purchased at Woodcraft. The later ones are celluloid blanks from CSUSA. Are the different materials part of this?
3. Do I need to rethink the finishing process that I've set up?
Any suggestions are welcome.
Thanks,
Mark
Thanks,
Mark
