Mike,
You have several choices: (1) vacuum the resin prior to casting, (2) pressure casting, (3) an additive called bubble eater, (4) ultrasonic jewelery cleaner, (5) vibrating table, (6) any or all of the above.[
] I have been using the ultrasonic jewelery cleaner for the last couple of months (thanks Bruce Robbins) and I really like using it. Look back in the casting forum or do a search and you'll find info on its use. Now, for something I've not seen reported here. I read an article in a rod making magazine about making reel seats. The author had made some snake skin reel seats and here is what he had to say (and I paraphrase): all of the materials we embedd in polyester resin has air in it. As the resin cures the air tries to escape and some of it gets trapped by the curing resin before it can escape. So, the author suggests to use uncatalyzed resin in the mold and let is set for a couple of hours. This will allow the resin to completely saturate the embedded material and the air is displaced by the resin. Then, empty the resin from the mold and add catalyzed resin and cast as usual. He suspends his covered tubes with a string into a jar of resin. I have just been pouring uncatalyzed resin in my mold and leaving it for a couple of hours. I emptied it and let the skins drip for a few minutes and then casted as usual with catalyzed resin. I like the result I had and will try more this way. I still used the ultrasonic and then pressure cast. Check your email.
Do a good turn daily!
Don
Originally posted by TheHoneymooners
<br />I'd like to hear an answer for the bubbles in the clear--last summer I tried a few clear castings of various materials & after 2 flubups with tiny bubbles (Don ho MIGHT have liked the concept, I didn't!) I just quit. It'll be nice to know what I did wrong--altho its BEEN so long I couldnt'tell you if I stirred it or poured it or what!!
