bushing help
scroller777
JBLM
Bushing question for you.
I have several bushings with no label, I do have a calipers to measure.
Once measured and go to the APP, I can see what pen its used with, could be 15 different pens.
When I'm at the store and like a particular kit, and it calls for a particular bushing, ie PKHPENBU. Well the measurement doesn't help me. So, using the app, how do I know if I have the right bushing already in my arsenal?
Any help would be appreciated.
Steve
Dehn0045
US
When you're at the store look up the pen kit in the app to get the bushing measurements rather than looking at the bushing code, compare to what you have.
Unsolicited piece of advice is to give TBC a try. If you have calipers then all you need is a dead center. No need to ever use bushings - eliminates a lot of stress when buying kits.
Bushings small price to pay. Try to stay with kits you know. If in doubt always buy a set of bushings. Nothing lost.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
You can enter the bushing part number (e.g PKHPENBU) into the APP search field, get a list of kits for that bushing, then click on one of them to get the bushing sizes & see if you have any that match.
scroller777
JBLM
thank you all,
I see the importance of retaining the numbers and information when it comes to the bushings.
Much appreciated
bassen
Loris SC
What App?
MikeyMike
What App?
There's an IAP BushNTube app on google play and the IOS app store. It has access to all of the data that you'll find in the Bushing and Tube spreadsheet in the reference area. It's pretty cool.
mmayo
Tehachapi, CA
Just a cautionary note, please verify the diameter of the kit components with a good digital caliper BEFORE you buy TBC bushings or have them made. There are many, many copies of different pen kits listed in the wonderful IAP bushing ap. Some are from different manufacturers and they may not match your kit which is from PSI. I know this because I had some bushings made using the wrong manufacturer and the resulting pen and finished tubes were not correctly sized. Just be sure with a caliper!
