harbor freight
  1. MRDucks2
    HF Dust Collector Upgrade Step #3
    In case you are interested, Step 1 was the Impeller upgrade and can be seen HERE. Step 2 was to build a Thein Baffle in a 35 gallon Brute Trash can and invert the blower above the trash can with a direct connection to the filter collar. You can see the end result in these photos but evidently...
  2. PapaTim
    Closed end handles finishing.
    I had a eureka moment yesterday while working on a handle for a back scratcher (Christmas gift). Many of you may have figured this out long ago but it just finally cracked through my noggin yesterday. When working on closed end handles, after parting off I've always found it challenging to...
  3. C
    HF Pressure Pot Lid Seal
    Any suggestions for getting a tight seal on the lid of my HF pressure pot?
  4. jplifka
    HF Pressure Pot Conversion Info
    I'm looking for Harbor Freight Pressure Pot Conversion info - I've read the one posted in the library but looking for other variations. The easy the better - I would greatly appreciate if someone could provide a link or attachment to any other variations they may know of - many thanks. R/John
  5. micah1_8
    Age-old question: drill chuck or drill press?
    The question arises again: Drill Press or Drill Chuck for the lathe Okay, here's the rub... The press can be picked up immediately, in-store. It's versatile, as in I can drill all sorts of stuff--however, I haven't, to date, had great need for a drill press--though it has come up...
  6. homerjatmoes
    Grizzly T10010 Grinder
    I want to try turning some acrylic blanks and knowing that I need some seriously sharp tools I started looking into sharpening systems. the first thing I looked into was what I could make for my 6" grinder or buy as an attachment. Although I would get sharp tools from my grinder, it would not...
