mobile band saw base
Jack, I got mine from Woodcraft when I bought the saw. It wasn't expensive and all I had to do was cut a piece of plywood that goes in the middle of the 4 bases.
I made mine from 3/4 Birch cabinet plywood. It is really sturdy and plenty of storage with 2 drawers. Only took 4 hours to build and cost less than even the HF base.
I built my own out of 1"x4" maple and 2" angle iron. It has fixed casters on on end and swivel casters on the other that are mounted on a pivoting board that opperates with a cam lever.
I have 3 of these in my shop right now for various power tools and need to build a couple more.
When not on the swivel casters, it sits on adjustable glide feet. Like in this picture:
A better pic....
byounghusand - nice mobile base. I just bought the same bandsaw and have been scratching my head about a mobile base - the one you built looks good. Do you have plans or is there a site where you got the idea/plans? Thanks
Don
I can scan them and send them to you... I will have to find them in the shop.... :confused:
They are out of an old issue of Wood Magazine (IIRC :rolleyes: )
Don
No reason, I suppose... Maybe one lever as opposed to two.... I dunno :biggrin:
That was the plans I found and it works for me.
I modified the plans I had slightly based on availability and ease of the build. So adaptatins are good.
This may be a silly question, but why not just replace the leveler feet with casters that have a matching thread?
like
http://www.woodcraft.com/Catalog/ProductPage.aspx?prodid=21977
or
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90999
or
http://www.rockler.com/product.cfm?page=11182&filter=caster
or
http://www.mcmaster.com/#casters/=62n9st
I'm sure someone makes a threaded stem locking caster that matches the threaded stem on your leveling feet.
Jack,
I've tried a few different styles of mobile base:
  1. Ones made from continuous sections of tubular (round or square) steel welded together to custom fit the tool. These are by far the best.
  2. Heavy welded steel plate corners that you bolt onto a piece of 3/4" plywood. These work acceptably well, especially for smaller-footprint tools such as bandsaws and sanders.
  3. Steel corners that you bolt 2x2s to to make a frame. These don't work. Even using good, strong oak, there's too much flex to roll the tool around.
  4. Telescoping steel frames that you bolt together at the appropriate size. These are iffy. The ones I've seen are not rigid enough and have too much flex.
I hope that helps,
Eric
byounghusband - thanks for the offer to scan - if you have the issue number of Wood I have the last 10 or 12 years of issues - I try to look thru their index too.
Don
That was my first try. It made saw kinda top heavy and kinda "tippy" feeling. I then build a plywood cabinet (partly because I needed the storage) and fit it around parts of an old cabinet saw mobile base.
I have this same base and it is great. Easy to use and moves very easily, even over uneven concrete. I would recommend it also.
I built my own in about an hour out of a piece of ply, 4 strips of oak on the edge of the ply where the saw base fits in and 4 wheels. Total cost about $10 plus the hour and I love it and have never had a problem.
