Fridge Magnets
See more from juteck
juteck
Charlotte, NC
What do you do with all of your pen blank cut offs?
Jim Smith
Lakeland, FL
Now that's one of the coolest things I've seen in a long while. Great idea and they should make terrific Christmas gifts. Thanks for sharing.
Jim Smith
sefali
Philly
That exactly why I have a box full of little cutoffs now. I just didn't know it till now. :biggrin:
juteck
Charlotte, NC
Thanks for your comments. These magnets were made by request of my sister, and ended up being quick and fun to do.
Where do you get your magnets?
I bought the 3/8" rare earth magnets from Lee Valley, along with the cup holders and friction discs. Woodcraft, etc., also sell the rare earth magnets.
Using a 4-jaw chuck to hold the rounded blank, I trued up the base and drilled a 1/2" hole using a forstner bit to fit the cup, and a 5/64" hole about 3/8" deeper, to fit a #4 x 1/2" screw. To turn the top side, I started using a jam chuck turned to fit the 1/2" hole, but didn't have enough grip, so I added a #4 screw, and made my own mini screw/jam chuck.
After assembling and inserting the magnet, I found that the magnets didn't always stay put in the cups like I expected and would stay stuck to the fridge, so I ended up epoxying them into the cup with J.B. Weld. Hindsight, I will use 1/2" magnets instead of the 3/8" magnets and cup, and just epoxy them in place.
RAdams
Banned
1/2"? How big are your blanks? Could you show some pics of the chucks maybe? and what is a cup holder and friction disc?
juteck
Charlotte, NC
The blanks I used were generally 3/4" to 1" square pen blank cut offs, by 3/4" to 1" long, or so. Some were a little less than 3/4" square, and turned down to a little more than 5/8" round. I'll set one up tonight and take a couple of photos of the screw chuck, etc.
Rare Earth Magnets:
http://www.leevalley.com/wood/page.aspx?c=&p=32065&cat=1,42363,42348
Steel Cups & Friction Discs (I did not use the washers shown on this page):
http://www.leevalley.com/wood/page.aspx?c=&p=32066&cat=1,42363,42348
RAdams
Banned
Thank you for the links! I look forward to the pictures. Some of my blanks are smaller than yours, but i could just scale down and still use em.
Another really good source for weird stuff like magnets, and some amazing gifts for young kids is a website called American science and surplus. I have ordered from them several times and have had no problems. And their stuff is AWESOME! I could spend a million bucks at that website.
bruce119
Franklin, NC, USA.
That looks like it mite just work. I made a whole bunch of book marks from cut offs and there just not selling. I guess people don't read books as much as they used too. Everything is digital heck they do all there reading on the net.
Thanks for sharing
Daniel
Reno, NV, USA.
Bruce, I did the same thing several years ago. I still have a whole bag of bookmarks that we don't even use around here lol. I really like this idea.
juteck
Charlotte, NC
Here's a picture of the jam/screw chuck I used to turn the magnet blanks:
And here's another with the magnet blank mounted, ready to be parted to length and shaped:
And a quick how-to is also attached for reference.
Alternatively, if you don't have a chuck, you can make a wooden morse taper as a jam/screw chuck, or use as a glue block for drilling on the lathe.
http://www.woodturner.org/community/youth/projects/MorseTaper_1.pdf
  • magnets.pdf
Daniel
Reno, NV, USA.
Thanks Mannie, that is more info than you can ever want about magnets, I knwo I read it all. Couple of thoughts that I am just looking for confirmation of.
in all the reading I saw that placing the disk magnet in a cup gives it 4 times the strength. On the magnet page itself a 1/2 inch disk magnet says it can lift a 9 lb steel block when sandwiched between to pieces of steel.
The way I am reading this is that a 1/2 inch magnet would have 9 lb of holding power if a cup and washer are used (Maybe just a cup) and 2.25 lb of holding power if just glued into a piece of wood.
Like I said I am just seeing if that is what others are reading as well. if so you could get the same 2.5 lbs in two ways. 1/2 inch magnet for $0.98 or a 1/4 inch magnet and cup for $0.88
It looks to me like this cup and magnet combo being the lower cost situation holds true for all of the magnets. Just a bit of a heads up on some not so obvious economy here. that is if my thinking is correct.
