Sandpaper help.
shadowbane
California
I seem to run out of 400 and 600 grit sandpaper rolls before I use up the other lower grit rolls. I have been unable to locate a vender selling only the 400 and 600 grit rolls....and well..I don't want to buy a pack containing the grits I already have too much of. Anyone know of any place to buy the 400 and 600 grit rolls?
Thanks,
Jeff
Jeff, just a suggestion, you could buy several sheets of 400 and 600 grit, cut them into 3/4" or 1" strips then cut the strips in half or whatever length you like. The sheets are far easier to find than the rolls and cost a LOT less.
If you insist on rolls, I'm guessing Klingspore has them.
Just a thought.
Lee Valley sells the individual 400 g rolls:
http://www.leevalley.com/wood/page.aspx?c=2&p=20182&cat=1,330,49236&ap=1
I've also purchased from Industrial Abrasives (prefer the LV but more expensive):
http://www.industrialabrasives.com/zencart/index.php?main_page=index&cPath=79_157&sort=20a&page=3
I also get 600 & 1200 g wet or dry at IA and cut as Texatdurango suggests -- very happy with these
http://www.industrialabrasives.com/zencart/index.php?main_page=index&cPath=74_106&sort=20a&page=2
Is that a sharpener bolted to your bed extension (shown in PIC)?
Barney
Barney
Barney, yes -- slow speed grinder in the photo. I stored it there for lack of floor/benchtop space -- I never operated the grinder bolted on the lathe. Grinding is messy IME so I do it outside when possible. I've since sold some stuff and moved the grinder.
I have a disc sander in that spot now and I do operate there because I can capture most of the mess with the vacuum. Here's photo of current setup:
We have a couple woodshows a year here that are close enough to drive to. I usually get enough to last me at the show including sheet paper up to 12000 grit eliminating the need for micromesh.
