New Stand
See more from hewunch
hewunch
Albany, GA
I made some new stands out of Lexan. Wanted to know what you thought of them. Oh, you are welcome to comment on the pens too.
Great idea,
Did you go through manay prototypes to get the balance right, or does it work at a wide range of angles?
Also, how's it go with different pen types? Can you ue the 1 holder for a large range of shapes & sizes?
Russell.
***See my next post***
So far, I have only tried the Jrs and Cigars. They both fit the same hole. I will try to make some for Sierras, Classics, etc.
OK this stand works for Jrs. w/threaded post, Cigars, Classic twist offs, Atlas/Polaris, 30.06 shell pens, and Sierras I know. It may work for others. I was able to balance a slimline in there, but it does not hold, like the others.
I will try to make some up this weekend for sale.
OK, I have made about 6 so far. And I have discovered I am far from "production" with these. Some are wider than others, some the hole is a little off center. BUT, these will be nearly indestructible. They are made from 1/4" Lexan, and I was thinking $1 each plus shipping (actual plus the cost of the padded envelope). I have the ability to make more if there is a demand.
