Larry Gottlieb
Will use of EEE on wood effect the use of BLO/CA following the EEE?
Larry
Larry
 I do MM after taking it to 600 wetsanding, so I dont know how much "finer" scratch removal it is actually doing, it's just been my standard practice and I figure if it aint broke, dont fix it.  Besides, I'm just killing time when I make them anyway, so the added time consumed doing it is a bonus.
  I do MM after taking it to 600 wetsanding, so I dont know how much "finer" scratch removal it is actually doing, it's just been my standard practice and I figure if it aint broke, dont fix it.  Besides, I'm just killing time when I make them anyway, so the added time consumed doing it is a bonus.Since I started using the Ultrashine EEE it just seems to bring out the richness of the wood, at least IMO, but then again, I'm easily impressedI do MM after taking it to 600 wetsanding, so I dont know how much "finer" scratch removal it is actually doing, it's just been my standard practice and I figure if it aint broke, dont fix it. Besides, I'm just killing time when I make them anyway, so the added time consumed doing it is a bonus.
Using EEE after 12000 micromesh is going backwards with regards to grit sizes. But, if it works for you that is all that matters.bdonald said:I do the EEE after my last MM,
My experience with wetsanding wood is the water raises the grain and makes the wood swell a little. But, once again, do what works and if it ain't broke don't fix it.I do MM after taking it to 600 wetsanding
Do a good turn daily!
Don
 I'm just going through the motions that I use, and keep learning every day reading the forums here. Thanks for the info.
  I'm just going through the motions that I use, and keep learning every day reading the forums here. Thanks for the info.I make pens like you do - as my creative outlet, for relaxation and to consume time. :biggrin:
AS to "bring out the richness of the wood", that is also referred to as "popping the grain" and some people, including me, use BLO for that. One thing that I do is after popping the grain - while the blank is turning on the lathe, I use a folded paper towel and let friction heat it up a fair amount. This helps the BLO cure/dry and the rest of the oiliness is wicked by paper towel. I personally have not had a problem with CA adhering to this.
Please note that this is not the same as using BLO as a mild catalyst for CA applications.
