Machine your own pen components, Anyone have any experience
Joshua_H
Kearney, MO
I'm not giving up kit pens, but I've become very interested in machining my own metal components and possibly even making entire pens from scratchas much as possible. I would still need to use stuff like Schmidt SKM click mechanisms or a high quality twist mech.I already make kitless fountain pens but i do want to work with more than wood and resin. The main components I'm interested in machining are tips, pen sections, accent bands, and cap finials.
However, I know very little about metallurgy or how to select the right material for a particular part. I'm hoping someone can point me toward some good resources or offer guidance on material selection. Stainless steel, aluminum, and brass seem like obvious choices. Copper, titanium, and bronze also interest me, although I understand that all of these metals come in different alloys whose properties I don't yet fully understand.
Any insight or recommended resources would be greatly appreciated.
Interesting question. My first thought is the raw cost of materials and time involved. Would the price of the pen be acceptable to whatever market you target? Good luck.
In all honesty I dont really try to sell my pens, I approach it as a hobby and I enjoy the process. It takes my mind off my day job and I have been blessed to have enough income to support this hobby. I have sold them it just isnt my main focus, I just enjoy creating things manually and I really like pens.
Thanks for the answer. Coming from manufacturing, I can appreciate the precision needed for the components.
Are you using a metal lathe, or a wood lathe?
My 3 non-precious metals of choice are;
304 Stainless Steel (hard to work on the wood lathe)
792 Nickel-Silver
504 Phosphor Bronze
Unfortunately, 2 and 3 are not available in small maker quantities here in Canada. And Online Metals in the States has a limited selection nowadays.
I'm starting to work with Sterling Silver, but it is an expensive prospect.
I've been debating on a metal lathe for quite some time now, to do just what you mention. Still haven't done it, but have also looked into alternatives. Certain brass mixes and aluminum can be turned pretty easy on the wood lathe for accent rings and things - some of my local AAW Chapter members use them frequently with good success using carbide tools. I've also looked at punches and presses that can cut rings and metal pieces. There have been a number of threads here on using metal, and a good video on turning an aluminum pen on YouTube by member Mark Dreyer. Check one out here
https://www.penturners.org/threads/turning-metal-on-a-wood-lathe.184902/
Kevin
792 Nickel-Silver
504 Phosphor Bronze
I own both a wood lathe, a mini and micro metal lathe, and a bench mill. I am good with my wood lathe but still learnig the other tools. All metal would be done on a metal lathe though, most likely the taig. I appreciate the suggestions,I will have to look into the availability here. Stainless is pretty easy to find but not sure about the other 2
Kevin
I took a metalsmithing class earlier this year to learn some of those skills too but Im not set up to to stuff like lost resin casting but the jewlerymaking aspect would come in handy when working with silver and precious metals. I think I bought the $580 Taig micro lathe starter package and did some very basic test cuts to some old brass and aluminum bar i had laying around of an unknown alloy and it cut very well. Just have to learn how use it. I bought a seig mini lathe probaly 5 years ago and the controller board blew on me so I never really learned anything on that. Working on repairing it now though
It's possible. It's a different mentality, you need to enjoy the process. I would start with good aluminum or stainless steel bolts you but at Home Depot. Online metals is a good source of interesting material. The only thing I buy for rollerball pens is the refill, spring, and the clip. I have done kitless click pens as well. I just buy the clicker. If you use threads to hold components together you will need to relieve the ends of everything to make things fit tight. Sharpening stones make polishing stainless easier. For final polishing look at your local auto parts store. Come spring I should have my shop back and finish the kitllless cigar pen I'm working on.
Your pens look incredible and is in the realm of what I am looking around doing. Getting bolts is good tip thanks for that. I really like having creative flexibility now that I am more than comfortable making kits. My Pen turners bible stays on my desk an I admittingly thumbed thru it so much that the biding is comming apart. Urushi finishing is on my list of things to learn too
I've only done it for my own entertainment - I don't have a market that'd command nearly the price the effort would require to sell - but I've done various parts in stainless, brass, copper, and aluminum (never tried the phosphor bronze). In a pinch, you could definitely hand-turn aluminum and possibly brass or copper on a wood lathe (I've done aluminum with carbide tools), but I wouldn't even try it with stainless - and I did mine on a 10" South Bend metal lathe.
The problem is that, while easy to turn, brass/copper/aluminum have a nasty habit of tarnishing and/or discoloring skin with much handling. I've found stainless is a bit of a pain to turn (hardly impossible, just a little annoying compared to something like 12L14 steel) even on a metal lathe if you aren't getting into the rigidity of 1000lb+ lathes (like the old South Bend Heavy 10, which I wish I'd picked up instead - my 600lb SB Light 10 tends to chatter on it).
You can, however, dodge the handling issue on aluminum by anodizing it, which can be done without too much more than a cheap variable voltage/current bench power supply and some grocery/hardware store chemicals. The bonus there is that you can also make it any color you want. I had trouble ever getting the richness I wanted, but I was only playing around with RIT dye, not the anodizing-specific dyes which are pretty readily available.
Now, titanium is easy to anodize into any color you want, and doesn't even need dyes... but reliably turning it? That's another matter.
I haven't had the spare shop time for working with metal in the past few years, but I'm happy to answer any questions I can remember the answers to.
-Bats
792 Nickel-Silver
504 Phosphor Bronze
I've never played with bronze - the closest I've come is brass (which obviously gets messy in a hurry) - how is it for handling?
And, yeah, subtractive manufacturing with sterling is obscenely expensive, unless you're going hard enough to invest in some sort of similarly expensive reclamation process for the turnings. Casting is more realistic (if, still, obviously raising the price of the pens dramatically - silver has been ridiculous lately), and then, if necessary, some minimal final machining to avoid waste.
-Bats
510 Phosphor Bronze machines quite nicely. I picked it because it has high corrosion resistance, and good fatigue resistance (for making clips).
I also took a silversmithing course, just before the prices skyrocketed. Now, I am slowly collecting silver at auctions when i can get it cheap (cutlery and stuff). With plans to melt it into useable sheets.
As of today silver is down to the low $40's, I may pick some up just for electroplating. Ive had good success with nickel plating, Ill have to look into if there is much difference in the process. Although probaly better to try it with sterling or argenium for the tarnish resistance
