Irish Bog Oak - CA or friction polish?
CaseyK
Angels Camp, CA, USA
I'm going to be turning some Irish Bog Oak here in the next few days, got the blanks from the Irish Pens site. I'll be using the Celtic kits from PSI in various finishes. I've not worked with Bog Oak before but it seems that it will be pretty straightforward. I want to do justice to the wood so would you recommend using CA, or would you go with one of the friction polishes/waxes? 95% of my work has been with CA so I'm most familiar with those processes. My most recent excursion into the land of friction polish actually turned out well on 9 bottle stoppers but I'm not sure if that was skill or just pure dumb luck.
I just started doing CA finishes. I had been doing friction polish and had been getting really nice results (EEE and Mylands liquid friction polish), especially when I started using a grain filler in really thin layers in between sanding. I've gotten really good results with both. I personally prefer the more durable finish you get with CA, though I haven't had any issues with friction polish, other than the time it takes to fully cure before handling. You just need to be careful to keep the applications super thin. So it's really a matter of preference. If you want a more natural looking finish and aren't in a hurry, go with the friction products. If the pen is actually going to be used a lot, go with CA. Being that the Celtic kits look kind of heavy, I'd most likely use the CA myself. Post pics when you're done!
Bog Oak needs to show its age with all its fissures. Some people get Bog Oak, fill in the fine lines, finish with CA, and it may as well be a piece of resin.........let it look like it is a few thousand years old.
I usually just buff mine and put a coat of Renaissance wax on.
There is a chap on this site from Ukraine who has turned hundreds of Bog Oak pens and he only uses Walnut oil.
There is a picture of one of his in the IAP collection.
I lifted this quote from @yaroslaw .........
I made more than a 1000+ pens from Bog Oak and found out that the best finish is a food-grade walnut oil. Give it plenty of time to soak in, buff it with steel wool, clean the residue and that's all. If you want a little more shine, the white diamond polish will do the trick without killing the texture.
I just turned a big oak pen a few days ago. I did a CA finish but will probably use Mylands next time.
This discussion is what I was hoping for. I love the CA finish but after finally getting the blanks into my hands the CA somehow doesn't fit with the reality of the Bog Oak.
I have walnut oil, Aussie oil, tung oil, and the 1:1:1 homemade friction polish, so there are options. The problem is that I'm not familiar with the nuances of these finishes so I'll have to think about this. And ask about this.
Thanks folks, please keep the info/feedback/knowledge coming.
I agree that Bog Oak needs to be felt when you pick it up and use the pen. I think even a friction polish would be too much.
I've used CA and it just doesn't look like a special pen. I used Lacquer (dont remember if it was spray or not) like John described and I found the feel of the pen made it special. Just enough to seal the wood, you dont need a heavy coating. I would think Walnut or Tung oil would be a nice finish also.
What would be the history to Bog Oak. I see its a peat bog enriched log but what would be the reasoning? Buried from flooding?
Bog Oak refers to the fallen branches and trunks of Oak trees that were submerged in Bogs, preserved from decay because of the anaerobic conditions. The acid in the bog water reacts with the tannins in the timber to naturally stain it black.
It is advertised to be 1000's of years old. No, that is not an extra '0'.
The supplier will have certificates of the timber's age that are supplied with the blank.
Many pieces of bog oak will have shades of brown along with the black . CA tends to turn the brown into black . I prefer to keep the colour differences as well as the tactility , so sanding to P1000 is all the finish mine get . A set of S&P shakers I finished with a tung oil sealer also turned black . Have never tried Yaroslav`s walnut oil approach .
Bog Oak is just one of those woods in a class by itself. It speaks for itself and the feel is hard to explain. That is why I believe it does not require a gloss finish. All this talk and I think I need to get some larger blanks and the salt and pepper shaker thing soumds good. May need a white wood for salt. To find a wood in the same class as bog oak for feel. Interesting. Any suggestions. Maybe a Holy with some grey running through it. Maybe something spalted.
If you paired this set with the Bog Wood I think that would look very good together. Spalted maple/bog set?
I suggest that you get some steel wool and dissolve it in vinegar and use it to make regular oak black. You'll have to turn the wood to finish size or into a dowel for testing. That will give you a bunch of black pieces to practice a variety of finishes on letting you see and feel the results. After practicing you can go on to the expensive Bog Oak pens and get the finish you desire.
Brilliant suggestion ! 👏 👏 👏
I prefer a friction polish or matte lacquer on bog oak. CA is a good durable finish but I wouldn't use it on bog oak. The reasons are the same as others have posted. It just isn't a good finish for bog oak. It would ruin that woods unique character. I've always wanted to turn a pen from sinker cypress but I've never found blanks. To buy a board and cut it up would be somewhat expensive.
