Trouble drilling on the lathe
johngmccune
Spring, Texas, USA
I'm having trouble drilling on the lathe because some blanks require the jaws to be at their extreme widest (and a few are simply too large) and for others -- like the rounded ones from Hobble Creek -- sometimes can't be held tightly even with the jaws at their smallest. Any comments or suggestions?
What I would do is first true the entire blank between centers. Get it as consistent as possible in size. 18, 19, 20 mm for the whole blank, then put it in a collet chuck, using an appropriately sized collet. Then, face off the exposed end to perfectly flat and drill your tube size. Your hole should be fefectly centered and ready for gluing in your tube.
Yes, it takes more time, but it increases your skill set. Try truing the blank with a skew to a perfect cylinder between centers. Your drilling will become much more consistent with a trued blank.
Something must be up with your chuck. The Hobble Creek blanks are standard size (3/4").
Can you show us a picture of of your chuck set up?
