How soon to turn when using 5-minute epoxy?
CaseyK
Angels Camp, CA, USA
Been using 5-minute epoxy gel to glue the tubes into the pens. I've always let it sit for a full day - glue it today, turn it tomorrow - mostly just because. No real reason.
My question is when could I turn these things if I'm using 5-minute epoxy? What would you set as the time you would wait to let the epoxy fully set? Not sure the answer would change my processes, but I would like to know what I could do if I needed to get some pens done more quickerly than normal.
I let mine sit overnight as well. If you need to push it, I would think a few hours of wait time would be OK, but I wouldn't trust the '5' minute claim as its more a working time number than fully cured time. Most packaging gives you the fully cured time on it in tiny print, so that might be your best reference.
Kevin
I've been using Barrel Bond 5 minute epoxy for a while, and I've never waited more than 10 or 15 minutes. I always stir it up with a piece of popsicle stick, then put the stick into whatever is left, usually not much, and wait until it holds there before turning. I've done this with wood, alumilite, inlace, faux stone, and several other resin-based plastics and the only problem I've ever had was one piece of frostbite inlace acrylester blew apart with a skew chisel, but when I inspected the barrel, there was a spot that didn't get any epoxy on it and that's where it blew apart.
Before I started using Barrel Bond, I used either generic 5 minute or medium CA from Hobby Lobby. I followed the same procedure, and didn't really have any issues with that either, but I still prefer the barrel bond for some reason.
I use Devcon Two Ton epoxy. Glue up a couple of pens as it has a long working time. Glue today, turn tomorrow. FWIW, had a kit for building a fishing rod that had 5 minute epoxy. Just barely got the grip on! Crossed off five minute epoxy.
FWIW... The BSI 5 Minute Epoxy states full strength reached in 1 hour. When I was using it, I still waited overnight.
I use mostly BSI 30 minute now as I prefer more open time and a stronger bond. Longer cure epoxies are stronger and more flexible (in general).
d_b
Seems like everyone is going overnight with the epoxy.
Sounds like if I'm letting things for for a day anyway I might want to go to the 30-minute epoxy for a stronger bond. I've never really checked/paid attention to/compared the bond strength vs. the set time so if I'm waiting a day anyway and I can get a stronger bond, might be worthwhile to go with the longer set time. I'll have to check that out. Thanks for the insight.
The main differences between 5-minute epoxies and regular cure full-strength epoxies come down to bond strength, cure time, flexibility, and water resistance. While 5-minute epoxy is designed for speed and convenience, regular full-strength epoxy is engineered for maximum structural integrity.
there is usually a full-cure time printed on the instructions. i follow that.
I just bought some 30-minute epoxy, same brand as I have been using, at the local hardware emporium. I actually looked at the back and it's a lot stronger than the 5-minute so I'll try it and see if I notice any difference. For sure it will make the tubing less energetic.
I use five minute epoxy and stir with a popsicle stick on a scrap piece of paper. Leave the stick and as soon as it hardens to the point that the stick is stuck good I turn it. Never had any problems and I am usually turning it within 15 to 30 minutes.
I have been using 5-minute for years and I follow the same regimen as Keith (KLJ). Same results too - never had any problems turning after about 15 minutes. (I'm just too impatient to wait overnight). - Dave
I will usually let it sit overnight, but I also have recently turned a piece using 5 minute epoxy after about 30-60 minutes and it was completely fine.
Keep in my that for the most part, the greatest "attack" on the bond (btw the tube and blank ) is shear force as a result of the force pruduced when a rapidly rotating blank (mass) repeately knocks into a stationery chisel. The blank is moving and the tube is held stationary by the bushings/centers. This force can be controlled by appling less shearing force (possible a gretaer mass) by using light cut and sharp tools. Naturally, we can turn before a full-cure is achieve because of the above. The real test of the bond is holding the blank stationary with plier/channel locks while a lathe with a lot more torque and without a load cut-off. Our lathes protect us from that. We also turning and then writing with pens. We really don't challenge the epoxy as much as it is formulated to withstand. Bottomline, if abbreviated curing time works for you (as it has for me on some occcaions), you will have more time to turm more pens or search for the springs and other small pen parts hiding under your equipment and fallen shop towels. lol When I started penturning and buying epoxy, I never understood why anyoen would buy epoxy that took up to 12 longer to cure than the quick-cure formulations. Then I call a few manufactures (probably distribitors) and they explained to me the realtionship between cure time and strengh. I found the 5 Minute working time BSI epoxy available at HL to be a good balance between strengh, cure time, and cost. It says 1 hour as mentiond above, I wait two (3 with a painted tube and/or blank). I wouldn't use it to repair the main mast on a tall ship. I am not recommending it; I personally found it to suit my needs.
