Conducting Batons
ruadh80
Carmel Indiana
I just got into turning. The best kind of hobby is one that your spouse gets something out of. So the first thing I started making are conducting batons for my wife who is an orchestra teacher. So far I have made them out of purpleheart, ceylon satinwood, curly maple, purple dyed curly maple (school color), acrylic and most recently purple ebonite.
She has also started giving them as birthday presents to her fellow orchestra teachers. The first person who received one was particularly fun because she is a young teacher who had only ever had cheap plastic "chinesium" batons. Good batons typically start around $75-100, not something a young public school teacher is likely to spend money on. So she was particularly excited to get a high quality baton that was properly balanced. The baton should balance right in front of the handle. The only way to achieve this is to add a weight inside of the handle.
I have been into woodworking for a long time, but had never gotten around to buying a lathe. I have to say, these are the most expensive woodworking tools there are! Not because of the price of the lathe itself, but because then you "have to" buy all the accessories. Everyone warns you... but you don't listen. I got a midi lathe because I didn't want to give up a bunch of space in my shop for it, but now I'm looking at getting more storage to hold all the chucks, collets, various tailstock attachments etc.. I now know that I should never buy a vertical mill. I obviously don't have enough self control to own something like that.
Nicely Done! Love the ebonite.
I have made a few of these and by using more dense woods, was able to get the balance right without adding weight.
So the handle is wood and you have to add weights to balance it? What makes the shafts so heavy? Having not done these before I am curious.
The total length is roughly 15" and the shaft is fiberglass. The fiberglass shaft is very light, but the handle is only about 2.5" of that 15", so even when I used purpleheart (which is relatively heavy) it still needed weight added inside the handle to get the balance correct.
When balancing the handle, where along the 15" length is the balance point? You just use something like fishing weights to balance it?
Very Cool!
I use .38 caliber lead bullets (0.358" diameter) to add weight to the handles of my turning tools. They fit nicely in a 3/8" inch (0.375") drilled hole. I usually add a few drops of epoxy when I put them in so they don't rattle around inside the hole. Although wadcutters would be ideal, I use round nose - flat point bullets because I have bunches of them already.
Dave
It should balance right where the handle meets the shaft. I bought a spool of 3/8" lead wire that I can snip off just enough to get the balance right and stick it in the hole right under the shaft.
Beautiful work. I've done a few batons for my kids band teachers, especially the student teachers as a thank you and graduation gift. I make my shafts from maple. I cut it into 1/4" x 1/4" x 18" blanks. I've found it faster and easier to sand it to shape from there. I plan on trying decorative inlays for balancing in future pieces. These 2 are black & white ebony handles with maple shaft.
Yeah, my wife breaks the wood shafts, so I have to do fiberglass. Here is a picture of a curly maple one with the whole shaft. IMG_3417.jpg
Very nice. Where do you get the shafts? I've made some out of maple but had requests for fiberglass
Steve
Originally I was going to buy fiberglass rod and turn it down, but I decided I really didn't want to deal with fiberglass dulling my tools and filling the shop with fiberglass dust. So instead I found that the cheap "chinesium" ones on the local multinational conglomerate trillion dollar e-tailer can be used sort of as blanks. They truly are garbage, the handles are poorly cast plastic and the shafts are unfinished splintery fiberglass that is way too thick for a proper baton. However they are super easy to pull the handles off, chuck in the lathe to sand down to a decent thickness and then paint with a white polyurethane. I wear a respirator and hold the end of my shopvac right next to the sandpaper as I shape it. A lot less work and much safer than starting with fiberglass rod. Definitely worth the $2 they cost (as a blank, not as a baton).
