Thanks David! I cast the runes directly into the ends of my blanks. I then fill in the runes with pigmented epoxy and back into pressure pot. Once they are fully cured I use that end of the blank for the finial, turn and polish as normal.Very Nicely Done Leonardo!
How did you do the cap finial on the Mage-Mini?
Thank you!Great work.
Thanks!Very attractive. Thanks for sharing.
Thank you!Very impressive job!
Thank you!Those are incredible!
Thank you. The pic with the all black background is just white light, and then the same pen under blacklight. It has both neon and glow in the dark pigments, which both pop under blacklight. The green at the tip is out of the blacklight and shows the color that it glows.Beautiful! Those last ones under black light (?) really POP!
