Some of my recent work
See more from Leonardo
Leonardo
Nashville, IN
Here is some info about the pens:
1. Mage-Mini - Parallel Section - Stranger Dreams Resin - Crimson inlaid finial
2. Magician - Parallel Section (not shown) - Bloodwood Resin
3. Magician - Parallel Section - Turbo Sunset Resin (Blacklight/Glow in the Dark)
4. Magician - Jowo 6 Section - Close Encounters of the Poured Kind Resin - Glow in the Dark inlaid Spiral Finial
Very Nicely Done Leonardo!
How did you do the cap finial on the Mage-Mini?
Thanks David! I cast the runes directly into the ends of my blanks. I then fill in the runes with pigmented epoxy and back into pressure pot. Once they are fully cured I use that end of the blank for the finial, turn and polish as normal.
It takes a little extra finesse as the epoxy can chip out if cut too aggressively, and sometimes I add a CA layer to seal everything and make it even.
Here's a look at the runes without infill. I am planning to add more designs. Some work better than others.
