Craft Supplies Scratch Freee
bugradx2
Chicago
Yes, I spelled that correctly.
I have been a long time user of Craft Supplies Dr Kirk Scratch Free and have a couple of questions for everyone.
Craft Supplies has recently rebranded the product and it's now called Old Mill Finish Co Scratch Freee Woodturners Polishing Wax and they have a second product that's called Old Mill Finish Co Scratch Freee Ultra Fine Woodturners Polishing Wax. Reading through the information on the site the two formulations seem to be close to what the two formulations from Yorkshire Grit are supposed to do.
They do say that it's food safe which is interesting.
My real question (s) is this. I've used the old original Dr Kirk's Scratch Free as a sanding sealer because that's one of the uses for the product they used to highlight. Can I use the Old Mill Finish Polishing Wax as a sanding sealer?
Any thoughts?
So, sadly Kirk DeHeer (Dr. Kirk) and Craft Supplies have apparently had a falling out. After many, many years of working for Craft Supplies, his employment apparently was deemed no longer needed for some reason. No more Kirk DeHeer on Craft Supplies site nor any Dr. Kirk products - which I also used a lot since they were really good quality.
Kirk now runs a company called A Cut Above Bowl Company Website . Kirk is an exceptional turner who I have had the pleasure of learning and turning with over the years. I am sure there is more to this story. Craft Supplies still shows the videos on turning staring Kirk, but he is no longer listed as an instructor at the Dale Nish School, nor listed anywhere on the firm's website.
Knowing what happened to Kirk, I have chosen to not buy the substitute products, nor most anything from Craft Supplies - but this is my own personal decision and should be considered as such.
A good alternative is the EEE polishes made in Australia and carried by Penn State Industries, Barry Gross or numerous others. EEE is offered in normal and extra fine, comparable to the Dr. Kirk products.
That's too bad to hear they separated. I will have to take a look at his site.
I would just switch to Yorkshire Grit (already have some) but their instructions say to use a sanding sealer which I would use the Scratch Free to do.
Sometimes this turning world is so confusing.
While everyone is on the subject of Kirks "Scratch Free product, I've always wondered.....since this product and others similar mention there ingredients contain a wax base, does this wax type product have any effect on future finishes that I might want to apply such as Lacquer since many finishes do not adhere to a wax base. I guess so far it hasn't effected me but I'd certainly like to know.
someplace in my reading I want to say you should wipe with alchohol or something prior to lacquer but please do not quote me on that because I don't know why that sticks in my head.
Great question. As a rule, unless I am using a friction finish on a piece where I have used any sanding paste, I normally clean the piece with DNA or something similar just to be sure it is contaminant free. With a friction finish like MyLands, my thought is the base coat of wax from the sanding paste just helps add more depth - as long as all of the grittiness from the sanding operation has been removed before doing the friction coats.
Kevin
I emailed U-Beaut Polishes Co. in Austrailia.....below is their reply:
The EEE is designed to be used under our friction polishes. Shellawax, Shellawax Cream, Glow, and Aussie oil.
As you say it is aa wax product and most other surface coatings will not work well over it due to this. However any of the friction Polishes will work beautifully. They are all made with our exclusive hard Shellac as the base for the polishes. When used it will give a high gloss finish that is about as tough as a melamine bench top. it is food safe and will last for very many years.
My suggestion would probably be to use the Aussie Oil as it can not only be used as a friction polish on the lathe but can also be used as a rubbed finish.
The ussie Oil will be available from PSI in PA or their narest distributor.
I hope this is of some help to you.
