Hickory pen
CMC75
Indiana
Hello woodworkers, wondering if anyone has a pen made of Shagbark Hickory. I have a lot of dried boards and wondering how it looks. Tried to search the key word"hickory" but still looking. Thought I would ask.
Also, (just starting pen turning) I read that not all pen kits are the same as far as quality even though they say they're the same. Can you help understand what to stay clear of in terms of buying pen kits?
For the hickory, cut some blanks and turn them. I have turned pecan which is the first cousin of hickory. Bit of coarse grain but can be finished good with sandpaper and CA glue. There are a bunch of sources for pen kits. I'll let the more experienced member chime in here.
First, the hickory you have will make some very attractive pens. Don't hesitate to use it.
Second, pen kit quality does vary. The main supplier from Taiwan who made a lot of the high quality kits turners liked closed and we are let primarily with Chinese manufacturers. There is one American made pen kit company that I know of.
All of that to say, don't stress over it starting out. I haven't had any major issues with the Chinese made kits over the years. Start out with what kits you like and can afford to just enjoy the process. Most of us started out with slimline kits and I still make a bunch of them. Don't get hung up over kit quality starting out.
Check out the resources tab for tutorials and many other things that can help you.
Could you tell me where to find this product?
We did make slimline pens in our class. My 10 year old did a good job for his first time on a lathe. His is the light colored wood. First pen making for both of us.
It's a two part-er.
First, I love how hickory turns. I don't know much about the specifics of the wood between shagbark and plain old hickory; however, they both have a nice contrast between the pale almond colored sapwood and a light reddish-brown heartwood. (I've seen the nice mix between sapwood and heartwood referenced as calico hickory. It is my personal favorite for tool handles and I always try to pick out hickory boards that have some mix of sapwood and heartwood. It should make great looking pens!
Part Two, Although there are many great suppliers that are members of IAP and commit heavily to the craft, my personal go-to supplier is Exotic Blanks from Racine Wisconsin. They carry many companies products as well as some that are of their own design. Ed Brown, Dawn Kizer, and their associates are top tier for customer service and all around pen turning expertise. (I think the kits you are referring to are likely PSI Slimline models.) Exotic Blanks carries these along with many other variety of slimline type kits. For slim ballpoint pens my preference however is the Streamline. Like me, it is a little thicker in the middle with a slightly larger center band so it does require different bushings (unless you are turning between centers without bushings).
Great looking first pens by the way, and of course, welcome to the IAP community! - Dave
PS I am also sending a private message to you following this post. Look for it by clicking on the little envelope at the top of the page next to your IAP username.
Dave
I've turned a few with Hickory. I'm not a golfer but I've read the first golf cubs were made from it. After reading that I made a few pens using golf balls and Hickory for my friends that golf.
Very interesting! I came across a kit of a pen for golfers. Looked like the thumb clicker was a tee. I am really there are endless amounts of pen varieties to buy.
Curious how you designed/built a golf ball into a blank?
I don't have a picture of the first one so the A&M pen is to give you an idea of the layout of the pen. I cut the center out of the ball and drilled the hole for the tube. I glued the ball on the tube and put it on the lathe to square up the ends and get the diameter close to the bushings. Then I drilled the caps being sure one end of the caps were perpendicular to the hole. When I glued the caps on the tube I was careful not to compress the ball and leave no gaps between the ball and caps. Once dry trim the ends and turn like any other pen.
The second pen I cut the skin off and thinned it as much as possible. Then I glued the ball on a painted tube and cast it in clear resin. That was pretty much it.
Made some beginner blanks over the weekend from a 2" slab of hickory. I realize that a few of them need to be stabilized but we don't have that option. Will try to turn them with the expectation they will come apart.
For the ones you noted need stabilization, flood those questionable ares of the blanks with thin CA before and after drilling and again before and during turning, it will help.
Wow! Gorgeous figure in that wood! - I think it is going to make some fantastic pens! - Dave
Little update-
Our lathe finally arrived and today my son and I got to break her in. The Hickory pen I set out to do did not work out. The Slimline kit was antique and after much confusion, the the first piece you press in ends up too short compared to all of the other kits we have on hand. We built 2 pens and on both the refill would stick out way too far. But we figured out why and will have to make blanks a little longer. The Hickory did look great!
We did a walnut from some of our board stock and an african black wood from a store purchase. Our finish was not good on the walnut. The sanding needs to improve. Both were tested with a friction polish finish. ALL CRITIQUES WELCOME FOR IMPROVEMENT AS WE GET GOING.
Decided to try the Hickory again. Cut some blanks to try to get the knot to show up. I tried to bond the gaps left after final sanding with thin CA but it left a bad haze and I couldn't seem to get it cleaned up. Got a lot to learn in sanding and buffing compared to the work I see posted around here. But it's addicting!
View attachment 394828Decided to try the Hickory again. Cut some blanks to try to get the knot to show up. I tried to bond the gaps left after final sanding with thin CA but it left a bad haze and I couldn't seem to get it cleaned up. Got a lot to learn in sanding and buffing compared to the work I see posted around here. But it's addicting!
One can experiment with finishing techniques and turning techniques. Some work, some don't. AMHIK BTW, one of the first pens I sold was a Slimline with a maple blank, finished with a blue Sharpie and CA.
Interesting, what made you do sharpie to color the wood?
