Wood Knot
On woods that are considered to be oily do you guys clean the blank inside with something before glueing the tubes in, I use CA glue.
Thanks!
Thanks!
How long do you have to wait after using epoxy to glue in the tubes before you can start turning the blank?I'm a heathen.... JohnU has not fully converted me to epoxy yet but he's getting there.
I've used thick or medium CA a lot of the time still but I know I'm playing with fire doing that. If the tube fits snugly in the hole then CA usually does the trick. I'm not in my shop at the moment but I'm pretty sure I'm using a star bond adhesive and it has a longer open time. I really make a point to make sure the entire inside of the blank is coated before I seat the tube to final position. I'll put glue on the tube, insert and push/pull and twist to coat as much of the blank as I can and then do the same from the other end. I've not had a glue failure in a couple years but there's always the next pen.... For me, CA even gets used on Olive which can be pretty darn oily.
That said, if I have a loose hole when compared to the tube or a particularly long single piece pen (think Long Clicker from EB) then I use epoxy because CA won't fill a gap and/or I don't have to worry about glue strength and coverage on a super long blank.
There is also a dedicated number of turners who use PVA glues (Gorilla Glue) to do their tubes. I think most of them recommend the clear type.
If I paint the tube or the blank then I default to epoxy also.
I'll also so that part of the reason I stayed away from epoxy was I started using JB Weld 5 minute epoxy and it absolutely stinks to high heaven. My shop is in our basement and it's one of the very few things my wife has ever complained about smelling upstairs. She doesn't even complain that much about spray lacquer. I swapped out to the Gorilla Glue 5 minute epoxy a couple years ago and absolutely love it. There's very little smell.
I'm the same as @egnald and generally just go start to finish on a pen in a session which is why I do like the CA. (I can be impatient too) You need to understand it's limitations and open time though.How long do you have to wait after using epoxy to glue in the tubes before you can start turning the blank?
Thanks.I'm the same as @egnald and generally just go start to finish on a pen in a session which is why I do like the CA. (I can be impatient too) You need to understand it's limitations and open time though.
With epoxy I try to give it as much time as I can. Ideally that's several hours to a full 24 but I've started turning after a couple hours before too. Using the gorilla glue it seems to muck up my sanding disc if more if it's not fully set up.
Thanks.I'm not a production pen turner. I will glue up several blanks with epoxy and let them cure overnight. BHuioj, I wipe the tubes with acetone.
Thanks.If I want to turn the pen that same day, I'll generally use 5-minute 2-part epoxy (claims to be fully cured in 1 hour).
If it's a more complicated glue-up (segmenting or similar), and/or I have time to wait longer, I'll use a 30-minute epoxy that fully cures in 24 hours.
I don't recall ever having a tube come un-glued from the pen when using either option. When I used to use thick CA glue, I had tubes come loose a few times, sometimes months after the pen was finished.
I don't degrease the inside of the drilled hole, even on super oily woods like rosewood or bocote. Epoxy doesn't seem to care. I do scuff my tubes aggressively with 150 grit sandpaper and then wipe all the brass dust off with a wet paper towel prior to glue-up.
Why would you need that much open time?I had been using 15 minute 2 part epoxy and letting fully cure (overnight) but have recently switched to 30 minute 2 part because I like the greater open time and it is a stronger and more flexible bond. I still let it cure overnight.
Thanks.If your looking for long time duribility, use Expoxy. It's on record and proven that CA bonds have poor resistance to shock, high heat, and continuous moisture, which cause the bond to degrade over time and definitely if your going to use CA, DON'T use excelerator. Excelerator is just a quick fix and causes the CA to go VERY brittle thus causing a super weak bond.
