Question about glueing tubes in blanks.
I will second the use of a good 2 part epoxy glue to always glue in tubes. This does 2 things. Gives a secure adhesion and also fill any gaps between tube and blank. Highly suggest this method. Added bonus it is more flexible and gives longer open times to insert tube. just need to plug the ends to keep epoxy from getting inside tube. but you should do this using any type adhesives. I like to use silly putty. cheap and easy to work with.
I only wipe the outside with acetone; don't do the inside. I now use Two Ton two part epoxy in twin four ounce bottles. Has long working time so I can do four or five pens at once. Plug one end with modeling clay...let the blank sit for a few hours and use a transfer punch to clear it. Note: i wipe the end of the tube with DNA as the clay leaves a residue on the tube.
I'm a heathen.... JohnU has not fully converted me to epoxy yet but he's getting there.
I've used thick or medium CA a lot of the time still but I know I'm playing with fire doing that. If the tube fits snugly in the hole then CA usually does the trick. I'm not in my shop at the moment but I'm pretty sure I'm using a star bond adhesive and it has a longer open time. I really make a point to make sure the entire inside of the blank is coated before I seat the tube to final position. I'll put glue on the tube, insert and push/pull and twist to coat as much of the blank as I can and then do the same from the other end. I've not had a glue failure in a couple years but there's always the next pen.... For me, CA even gets used on Olive which can be pretty darn oily.
That said, if I have a loose hole when compared to the tube or a particularly long single piece pen (think Long Clicker from EB) then I use epoxy because CA won't fill a gap and/or I don't have to worry about glue strength and coverage on a super long blank.
There is also a dedicated number of turners who use PVA glues (Gorilla Glue) to do their tubes. I think most of them recommend the clear type.
If I paint the tube or the blank then I default to epoxy also.
I'll also so that part of the reason I stayed away from epoxy was I started using JB Weld 5 minute epoxy and it absolutely stinks to high heaven. My shop is in our basement and it's one of the very few things my wife has ever complained about smelling upstairs. She doesn't even complain that much about spray lacquer. I swapped out to the Gorilla Glue 5 minute epoxy a couple years ago and absolutely love it. There's very little smell.
How long do you have to wait after using epoxy to glue in the tubes before you can start turning the blank?
I used to use thick or gel CA to glue the tubes into the blanks. On rare occasions I would have a tube seize up before I had it fully inserted. I started using 2-part 5-minute epoxy due to the number of members recommending it. For maximum adhesion many recommend epoxy with a longer working time and they also recommend letting it fully cure overnight before turning. I tend to be more sporadic with my decisions to turn pens, and by nature I am impatient, thus the reason I was using CA in the first place; however, even with 5-minute epoxy, I usually start turning after letting it set up for somewhere between a half an hour and an hour. So far I haven't had any issues. - Dave
I had been using 15 minute 2 part epoxy and letting fully cure (overnight) but have recently switched to 30 minute 2 part because I like the greater open time and it is a stronger and more flexible bond. I still let it cure overnight.
I'm the same as @egnald and generally just go start to finish on a pen in a session which is why I do like the CA. (I can be impatient too) You need to understand it's limitations and open time though.
With epoxy I try to give it as much time as I can. Ideally that's several hours to a full 24 but I've started turning after a couple hours before too. Using the gorilla glue it seems to muck up my sanding disc if more if it's not fully set up.
If I want to turn the pen that same day, I'll generally use 5-minute 2-part epoxy (claims to be fully cured in 1 hour).
If it's a more complicated glue-up (segmenting or similar), and/or I have time to wait longer, I'll use a 30-minute epoxy that fully cures in 24 hours.
I don't recall ever having a tube come un-glued from the pen when using either option. When I used to use thick CA glue, I had tubes come loose a few times, sometimes months after the pen was finished.
I don't degrease the inside of the drilled hole, even on super oily woods like rosewood or bocote. Epoxy doesn't seem to care. I do scuff my tubes aggressively with 150 grit sandpaper and then wipe all the brass dust off with a wet paper towel prior to glue-up.
Thanks.
Thanks.
I swab out the inside with denatured alcohol on a q-tip, and I've been using Barrel Bond 2 part epoxy. It's worked well on katalox and bocote, the two oiliest woods I've used. Barrel Bond seems to be more expensive than most 5 minute or 15 minute epoxies but it does a great job of filling gaps and cures fast enough to get everything done in one session but still capable of doing 3 or 4 pens at once if you're prepped well.
Why would you need that much open time?
First of all, I find that the published time for epoxy is almost double what I am comfortable with. For example, the 15 minute has 7-8 minutes of good open time before it begins to thicken. For kit pens, this is more than enough time and I still use it.
For bespoke (kitless if you prefer), I am now using the 30 minute, which nets me a good 15 minutes. I want the additional open time to make sure that I am able to get everything situated exactly correctly. Gluing a handmade liner/sleeve into a barrel or cap can be a bit tricky for a number of reasons.
The other reason has nothing to do with open time, but with flexibility and strength. The longer the cure time, the more flexible and strong bond you get.
Thanks for asking!
Other than blowing forced air through the hole, I don't clean hole. Maybe u r using a wood that I haven't.
