Beall Pen Wizard Parts Identification ?
Bob Roehrig
Venice, Florida
Hello all......have a good lead on a used Pen Wizard in excellent condition. Fella never used it so does not know what many of the parts do. Has several of the parts laying on a board. Looking at them I have no idea what they are for and what purpose if any they serve on the machine. I've attached a picture below in hopes maybe someone can help identify what they are and if they indeed go with the machine. From left to right it starts out with a small plastic bags that looks as if it has a spring and some other small parts. Skip the allen keys, Then theres a steel sleeve with an open slot going vertically in it. last is a steel round block....possible something is missing off of this??? Any help would be appreciated since no one I know has any idea what these are. Thanks in Advance.
I suggest you look up the instructions for that machine. They are out there. There are videos of it being used as well. There use to be many u-tube videos out there. Look for those. he also put out a DVD that was lengthy that explained how the tools worked. Would be a great find if you can get that. Maybe ask around if anyone has that too. Many ways to attack the new adventure you are taking on.
https://www.penturners.org/threads/pen-wizard-owners-discussion.38769/
https://www.bing.com/videos/riverview/relatedvideo?q=pen+wizard+forums&refig=6a6e9a6bb4f84b7eaa6a69aa38d52d83&pc=HCTS&FPIG=159899BABDEB4EAA92B51F524384F48B&first=25&ajaxnorecss=1&sid=270B952EEFE26CEE2D498287EEDA6D88&jsoncbid=1&ajaxsydconv=1&ru=/search?q=pen+wizard+forums&refig=6a6e9a6bb4f84b7eaa6a69aa38d52d83&pc=HCTS&FPIG=159899BABDEB4EAA92B51F524384F48B&first=25&FORM=PORE&ajaxnorecss=1&sid=270B952EEFE26CEE2D498287EEDA6D88&format=snrjson&jsoncbid=1&ajaxsydconv=1&mmscn=vwrc&mid=BBD21FB962ABFB9589D8BBD21FB962ABFB9589D8&FORM=WRVORC&ntb=1&msockid=21f436cd8e1211f1af5d2f2ce36f5b83
https://www.penturners.org/search/131092/?t=post&c[users]=jrbeall&o=date
Hi John, Yes, been trying to find someone to burn me a copy of the Beall original CD that came with the machine... No luck so far. To bad something like this is not in the IAP libary for all to reference. I"m sure finding a disck to copy is going to prove to also be a challenge. Bet Jerry Beall has a stack of them sitting in his bedroom :D
Have you tried looking in the Wayback Machine for Jerry's pages from 10 years ago?
Sounds great but not sure how to access those pages. Could you please explain.......thanks
"The Wayback Machine" is an internet archive that stores copies of web sites as they are at a specific instant. And it keeps them, going back decades, allowing you to look at a website which perhaps doesn't exist any more, as it was the day the copy was made.
I get there using a Google search for "wayback machine" and this is the first result listed:
Click on that link, it takes you here, and type in the site you are looking for (you have to know its address, but I can guess this one)
First display is a calendar showing the available image dates that are in the archive:
Choose a date that is likely to hold the information you're seeking - I picked February 2015 (you can step backwards and forwards in time if this misses the information you are trying to find):
Click the "Instructions" link, as there's a pretty good chance that's where I'll find what I'm looking for - hey, look what I got, a list of all Jerry's instruction docs available on that date.
Usually the document links are live and PDFs are also archived, but sometimes the web designer made it difficult for the wayback machine to index and retrieve them.
Hope this helps.
I can't really tell what the part is in the first photo. In the second photo the gear looks like it is the 12 tooth gear that matches up with the 60 tooth gears. The other part may be the crank for the Guilloche attachment (see the photo). I'm not sure what the tube is on the left.
Hope this helps.
Hi.....got into the Wayback Machine site. Unfortuanately the menue items they had for the Pen Wizard are items already published on YouTube and available on the IAP site which I already have. Thanks for tip. The site looks good and very useful. Will bookmark it.
Yes, the round disc did go with the Guilloche attachment. Now back on the machine and glad to know it's an integral part that's important. The round tube with the slit is a mystrey and I really don't believe it goes with the machine itself as well as that spring with nut and "O"Rings. Glad that's cleared up.....now just looking for some better instructions on it's use. Not quite familar with the machine and with all the gears, slides, rods, and adjustment it's a little intimidating. Jerry Beall once had many video's on YouTube but for some reason deleted them and there's only 3 video's of his left on YouTube. Will keep looking and thank again for your help.
The documentation that came with the PW was not that great. I may have the disc. I will look and see.
try contacting JR Beall for any info he may still have.
Ed Davidson(aka yoyo-spin) had several videos. maybe he can be helpful.
If it is a 14 mm or 1/2" brass tube, that would be similar to the diameter of the tube that came with the upgrade package for the Pen Wizard called the Transformer Package (see the first photo.) These upgrades allow the cutters to move along the contour of the work piece. You mentioned the other photo was of a spring, and the only spring I have is on the depth guide that comes with the accessory package (see the second photo.)
I was lucky and did receive the new Depth Stop with my recent Wizard purchase. What I really like is the older brass tube depth stop but unfortuate that my model Dremel does not have the recessed slot that the tube slips up into that Jerry Beall describes in his one YouTube video. Do you by chance happen to know which Dremel models happen to have that future? I made a tube type depth stop for my Spiral mater router I use and really love it. If I knew which Dremel to buy that has this feature, I'd look for one on Marketplace. They work GREAT!!
