Well, here is my first assessment of the PW. First of all, since I have the MillLathe, I have another mill with which to compare the PW. I used the foredom handset and the rope twist router bit mentioned earlier. There is what I consider a problem with the PW using this bit. The platform on which the cutting tool rests is free floating. Because the cutter floats and the rope bit takes such a large bite(1.2 inch diameter), the bit itself did not stay at the depth I had it set. Several passes were necessary and I finally had to hold down on the cutter mounting platform to keep the bit at the depth I wanted. This may not be a problem using bits that take smaller bites. Or, maybe I'm missing something and will get it figured out.
The MillLathe has a mechanism that locks into place once the cutter depth is set. I've attached a picture of my millLathe for those who aren't familiar with it.
The PW does do have the Guilloche attachment and the Milllathe does not. This is my main reason for getting the PW.
The PW has GEARS and my MillLathe has belts that tend to slip. I love the gears instead of belts.
I'll be playing with the other features of the PW tomorrow and will probably continue to do the rope twists with the MillLathe.
But, the PW is a fun tool and I look forward to the many things it will do that my MillLathe will not.
Do a good turn daily!
Don
